after my storagenode run out of space with -150GB schown as available space, i tried to remove the current container and create the container again.
The storage destination is the same as the first container.
Also the other settings, including the identity.
But it does not find the space , where all of the folders ( db / storage etc.) are stored.
What can i do ?
Before i removed the first container, i stopped it with
docker stop storagenode
Attached the logs:
2020-01-26T19:18:01.227Z INFO Configuration loaded from: /app/config/config.yaml
ERROR version Failed to do periodic version check: version control client error:
ERROR collector error during collecting pieces: {“error”: “context canceled”}
ERROR bandwidth Could not rollup bandwidth usage {“error”: "bandwidthdb error: context canceled; sql: transaction has already been committed or rolled back
FATAL Unrecoverable error {“error”: “piecestore monitor: disk space requirement not met”, “errorVerbose”: "
the destination is the same. I ve stored the command to create the storagenode.
I dont want to create a new storagenode. I would like to use the current storagenode but in an new container.
