Storj bindings and developer tools, a list
Storj DCS works with leading dev tools, apps, and services, providing decentralized cloud storage that’s secure, private, durable, and drop-in compatible.
Our Partners
Logos of Couchbase, Filezilla, InfluxDB, Minio, kafka, MongoDB, MariaDB, Plesk, Nextcloud, Pydio, Zenko, Filebase
Featured Integrations
Fastly Fastly
Use Storj DCS as the endpoint for log streaming/CDN origin.
(https://www.storj.io/integrations/fastly)
FileZilla FileZilla
Transfer files simply and securely using FileZilla
(Setting Up FileZilla for File Transfer - Storj Docs)
More Integrations
Filebase Filebase
S3-compatible object storage, with no API keys to manage.
(https://www.storj.io/integrations/filebase)
Node Dashboard Node Dashboard
Visualize your current performance metrics as a Node Operator.
(https://www.storj.io/integrations/node-dashboard)
Developer Tools
Duplicati Duplicati
Automatic backing up to Storj DCS using Duplicati.
(Cloud backup storage lowers security risks | Storj)
Backup for Restic (tech preview)
Backup and instance using Restic.
(https://www.storj.io/integrations/backup-for-restic-tech-preview)
Sync for RClone (tech preview)
Map your filesystem to the decentralized cloud.
(https://www.storj.io/integrations/sync-for-rclone-tech-preview)
MongoDB
MongoDB
Periodically snapshot and store backups of your current MongoDB instance.
Libuplink Go Library
Programmatically interface with Storj DCS.
(https://www.storj.io/integrations/libuplink-go-library)
Uplink CLI Uplink CLI
Upload data to DCS directly from the CLI(Cloud Object Storage Services | Storj)
Storage Node Software Storage Node Software
Monetize your excess hardware capacity with Storj.
Bindings
.NET Bindings.NET Bindings
Software bindings from native Go language library for developing applications in .NET.
(Storj Partner Library: The best way to store data in the cloud.)
Android Bindings Android Bindings
Software bindings from native Go language library for developing applications in Android.
(https://www.storj.io/integrations/android-bindings)
Swift Bindings Swift Bindings
Software bindings from native Go language library for developing applications in Swift.
(https://www.storj.io/integrations/swift-bindings)
C Bindings C Bindings
Software bindings from native Go language library for developing applications in C.
(https://www.storj.io/integrations/c-bindings)
I would like to suggest pinning this post to this category if it’s possible.
good idea… i debated whether it should be under faq or getting started
i think it makes sense here in faq, because the tools would be used after the step of setting up an account.
i’ll go ahead and make this so that it’s stickied, but can be unpinned by the visitor. thanks for the validation
