As you said i setup it like that but still not working my subdomain doesn’t work. Error | Storj DCS (pixahunt.com)
Hello @shajal,
Your registration information on the domain server.pixahunt.com is missing.
it should have:
$ORIGIN pixahunt.com.
$TTL 3600
server IN CNAME link.storjshare.io.
txt-server IN TXT storj-root:<bucket>/<prefix>
txt-server IN TXT storj-access:<access key>
What Is $ORIGIN pixahunt.com. i don’t use my main domain
This is a “subfolder” inside the bucket. Object storages supports only buckets and objects, the prefix is a part of the object name, but can be visualized as a subfolder.
If you do not use prefixes, then you do not need to specify it in the TXT record.
It’s your main domain. This is a usual declarative description for your domain. You can register CNAME only for subdomains, in this case server.pixahunt.com.
Your screenshot with DNS records looks almost correct, but you need to remove a trailing slash from the bucket, if you do not provide a prefix after. Please note, SSL is available only for paid accounts, if your account is not paid, it will not work.
On CloudFlare you need to switch to a Flexible mode for encryption, unless you have a paid Storj DCS account, then you can use SSL option and enable Full (strict) mode: Setting Up Custom Domains - Storj Docs
Right now your TXT record for storj-access: in your DNS is incorrect, you need to specify there not your access grant, but access key from S3 credentials, created for this bucket when you used a command
uplink share --dns server.pixahunt.com sj://pixahunt
It prints needed records at the end.
You need to use the access key jv26qxslzuip7t2wuk7bd4ik4baq:
txt-server.pixahunt.com. IN TXT storj-access:jv26qxslzuip7t2wuk7bd4ik4baq
Now it works, but needs correct permissions: https://server.pixahunt.com/pixahunt/378052964_761684185972028_20811060944673859_n.jpg
https://server.pixahunt.com/378052964_761684185972028_20811060944673859_n.jpg
Did you remove the root access grant from the account? If so, all derived accesses are revoked.
You may check:
uplink ls sj://pixahunt
If it’s still working, then you need to generate a valid access (valid for 2 hours):
uplink share --dns server.pixahunt.com --not-after=+2h sj://pixahunt
or valid indefinitely:
uplink share --dns server.pixahunt.com --not-after=none sj://pixahunt
and update your storj-access: record in DNS.
it’s work. will my link ever change?
What do you mean?
It may change, if you update registration or configuration of your DNS, you may also move objects to a different bucket or use prefix(es) inside the bucket.
sir i want to off Switch passphrase
What do you mean? If you are talking about access your buckets and objects via Storj Console (the Satellite web UI), then it cannot be disabled - we doesn’t store your encryption phrase, it may be temporary stored in your local browser session, but as soon as you refresh the page - it will be lost and you will need to provide it again.
Please use the same encryption phrase used during upload to get an access to these objects.
