You need to keep it online for the next 30 days to recover the online score.
Thank you. I will monitor the score to see if the problem is just the DDoS protection, or there are other underlying problems.
This is not a good test if you suspect overzealous firewall.
This is great, but should have been done 22 hours ago, when we literally discussed
Also, small request, in the future, please donβt post pictures of text. Post text itself. Not only itβs impossible to read, but also impossible to search. Itβs much easier for you to copy and paste text, than for everyone who tries to help to OCR your picture to grep for words.
For logs t to look good in the forum post paste them between series of backticks, with optional format hint, like so
```log
Meow! This is log message
this will look like so
Meow! This is a log message
Iβm also using a MacBook, and yes, it does OCR on the fly, but it still five extra steps. I need to select text on picture, copy it to a text editor, then search. And I only get one screen worth of truncated line-wrapped text, which may fail search because word is split in half. Why go though all that? Command Shift Option 4, space, β which is what you alegedly did - is harder than Command+A, Command+C ![]()
If you want to learn more about discourse formatting β you can read here:
My favourite, if overused, feature is to swipe less important text or image into under the disclosure triangle, so only those who care will see it, thus avoiding cluttering the post.
if I type this:
[details=This is my cat]
<and paste picture of my cat here>
[/details]
You will see this:
This is my cat
cat picture goes here
