hi,
I have created a LXC container for storj
> gergo@dl380p:[~]:lxc config show storj
architecture: x86_64 config: image.architecture: amd64 image.description: ubuntu 18.04 LTS amd64 (release) (20200317) image.label: release image.os: ubuntu image.release: bionic image.serial: "20200317" image.type: squashfs image.version: "18.04" raw.idmap: both 1002 1002 volatile.base_image: 98e43d99d83ef1e4d0b28a31fc98e01dd98a2dbace3870e51c5cb03ce908144b volatile.eth0.host_name: veth763ae1fb volatile.eth0.hwaddr: 00:16:3e:59:9b:38 volatile.idmap.base: "0" volatile.idmap.current: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":1000000000},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]' volatile.idmap.next: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":1002},{"Isuid":true,"Isgid":true,"Hostid":1002,"Nsid":1002,"Maprange":1},{"Isuid":true,"Isgid":false,"Hostid":1001003,"Nsid":1003,"Maprange":999998997},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1002},{"Isuid":true,"Isgid":true,"Hostid":1002,"Nsid":1002,"Maprange":1},{"Isuid":false,"Isgid":true,"Hostid":1001003,"Nsid":1003,"Maprange":999998997}]' volatile.last_state.idmap: '[{"Isuid":true,"Isgid":false,"Hostid":1000000,"Nsid":0,"Maprange":1000000000},{"Isuid":false,"Isgid":true,"Hostid":1000000,"Nsid":0,"Maprange":1000000000}]' volatile.last_state.power: RUNNING devices: camera: path: /mnt/storj source: /mnt/storj/ type: disk ephemeral: false profiles: - default - bridgeprofile stateful: false description: "
did the installation preparations on storj website, everything was OK, but when I try to run storj docker I get the following:
gergo@dl380p:[~]:lxc exec storj bash
root@storj:~# docker run -d --restart unless-stopped --stop-timeout 300 -p 28967:28967 -p 127.0.0.1:14002:14002 -e WALLET="0x621Cd13b72bCB6Bc0698c46C8D349224c9a810f8" -e EMAIL="gergogyerek@gmail.com" -e ADDRESS="gergogyerek.duckdns.org:28967" -e STORAGE="3TB" --mount type=bind,source="/home/storj/.local/share/storj/identity/storagenode",destination=/app/identity --mount type=bind,source="/mnt/storj/",destination=/app/config --name storagenode3 storjlabs/storagenode:beta
0a14d25782287387bd8df4158a5d365465a34e8e159267da7c4c0c50b4581712
docker: Error response from daemon: OCI runtime create failed: container_linux.go:349: starting container process caused "process_linux.go:449: container init caused \"rootfs_linux.go:58: mounting \\\"proc\\\" to rootfs \\\"/var/lib/docker/btrfs/subvolumes/e8c3546934a8b3b51fd1d2913f21246506a3313313eedb5e115b421d92e1f082\\\" at \\\"/proc\\\" caused \\\"permission denied\\\"\"": unknown.
could someone guide me to the right troubleshooting directions. what should I check?
I’m trying to mount storage from the host to lxc and give it to storj.
thank you
Gergo
