Storj install for Synology
I have created my identity and trying to copy over the files but getting this error
craigferstorj@zzzname:~$ sudo ls /root/.local/share/storj/identity/storagenode
ca.1715852628.cert ca.cert ca.key identity.1715852628.cert identity.cert identity.key
craigferstorj@zzzname:~$ sudo cp -r /root/.local/share/storj/identity/storagenode/volume1/docker/storj/identity
cp: missing destination file operand after ‘/root/.local/share/storj/identity/storagenode/volume1/docker/storj/identity’
Try ‘cp --help’ for more information.
Is it just an issue where you need to wrap the path in quotes?
I’ve been watching Youtube video along with the instructions and the guy online doesnt have the path in quotes
You are missing space between storagenode and /volume
