Storj.io/clone setup git workflow is no longer work
In https://github.com/storj/storj/blob/1ef5bfe40caa8b081825ccb8e89294d3988931fb/DEVELOPING.md
This step no longer work:
curl -L storj.io/clone | sh
It’s an oversight or ..?
I notice AuditRepairWeight and AuditUplinkWeight is no longer used in code, so try to create a PR to remove those configs.
We migrated our site too. Perhaps something missing.
Notified the team.
It has been fixed
Hi @Alexey, this is probably nothing, but I’m just being precautious.
So previously, https://www.storj.io/dcs-satellites will redirect into https://static.storj.io/dcs-satellites.
But it seem now, this is 2 separated sites:
https://www.storj.io/dcs-satellites seem to be on github (server: GitHub.com).
https://static.storj.io/dcs-satellites is a different site (?).
Could have situation where 1 site is update but the other is not (but if you plan to deprecate https://static.storj.io/dcs-satellites, this is right then).
Actually we wanted to deprecate https://www.storj.io/dcs-satellites, if you request storagenode setup --help | grep trust.sources you will see that https://static.storj.io/dcs-satellites is a default option.
However, on many old nodes this parameter wasn’t commented out in the config.yaml file, like now.
There is an easy fix. In the next node update, add check that if. old address is present to replace it with the new. Then after everyone updates node, old one can be shut down.
That runtime check can stay forever in the code.
