Is there a link to the blockchain to check? Haven’t receive mine yet (not worrying) just last time I could see the alphabetical order. And yeah, was lazy, maybe the same address? ![]()
I still haven’t received anything, but I can see that the amount has been added to the “Undistributed payout” balance. Is there a minimum payout threshold?
Same link every month.
There are some payouts less than a dollar so less than that
Only 3 fifths of the way so far
Dude. Relax and wait. What is this panic at every payout?
And stop looking at dashboard. Dashboard updates later. Much later.
Most likely because the previous node version displayed calculations based on the old rates. After upgrading to v1.164.2 this week, the expected payout adjusted to the actual figures for October.
At some point even older node version got new rates from satellite and applied them at calculations (node restart was required). It happened somewhere at the beginning of 20th of September.
If you are EU resident, you must use your private self-custodial wallet due to MiCA. There is no workaround.
You will be unable to confirm the ownership of our wallet address.
See
I can recommend to ask them to resend your funds to your own wallet. We cannot help you with any exchange.
Got my USDC on the same ERC20 address used for Storj tokens in Binance, cheers all
seems the USD payment i received does not match what my node say the sattelites will pay. i have two nodes. one of the nodes aays 36.35 from 4 of the satelites, the other node says 24.12 from 4 satelites, but i got $33.11.. so it seems i only got paid $33.11 even though it says $36.35 + 24.14… i have 2 nodes with different emails addresses on same wallet.
I received a fair amount of USDC as well, transaction came in 6 hours ago. I wanted to post yesterday evening that i didn’t see anything yet but giving it a bit more time solved that automatically ![]()
Not fully sure if it’s the full amount with the graceful exit etc but it should be relative close to it and if something comes later due to chapter 11 etc then I’m sure it will go through..
I manage four wallets across four different sites. The first three payments I received matched the expected amounts, while the last one was only about 60% of what I should have received.
Anyway, with all this chaos, it could also be a mistake on my end (although I used the same method that matched the other payments).
occupied whole september on disk: 8.5 TiB
node dashboard: 6.75 TBm
plus ALOT of traffic
Should be around $15
Was only $5
Old node, so no held back amount
I’ve figured out the reason - satellite/compensation: prepayment for nodes staying in the network · storj/storj@f4883c3 · GitHub
If your node has reached the 16-month mark by the time the calculation is made, you will receive a prepayment that compensates for July.
If your node has not yet reached 16 months, you will receive even less than what you actually earned that month.
would explain it. node is 13-14 month old
So if multiple nodes are useing same wallet, then payout is sum as single transaction, for all of them?
i would of thought so, but my nodes show what the satellites will pay out, and that doesn’t app up. When it was in storj token, it was harder to match things up so i never knew 100%. but now things are in USDC we can see if they match up.
so for 2026/09 my node stored 8.5 TiB of data and was paid $5.50
that equals $0.65/TBm (including traffic, including trash).
