quick question about coinbase storj address, we need to update payout address to USDC address (still coinbase) . Or Currant coinbase storj address will be enough to receive USDC ?
Nothing has changed, the quick answer - don’t use the exchange’s deposit as your wallet in the node’s configuration and you will not lose anything.
More long - you must take a new deposit address specifically for USDC. They may also have a minimum deposit requirements, so your funds could be lost by default. We will not help you.
If you are a EU resident, your funds will be lost without a doubt, you must use your own wallet, you are out of options.
In short: if you use an exchange address instead of your own wallet, you will inevitably lose your funds—sooner or later. Use only your own wallet. Make your decision after that.
Yes, you need to stop and remove the container (otherwise it may revert your changes), comment out the wallet feature, save the config and run the container back using all your parameters.
And @LrrrAc is correct to, you may do nothing and the payout will go to L1 address anyway.
Unfortunately it’s confirmed by many support requests. Exchanges may decide to stop withdrawal, block the account, delist the token, change the address, etc.
Unfortunately it’s sometime true too in some regions.
However, it’s not the same. Funds on your wallet it’s more like storing gold jewelry or precious stones in your own safe.
But what I mean - don’t keep your funds on the exchange longer than is needed to exchange them. Or even better - send to it when you are ready. Otherwise it’s risky.
I don’t know for sure. Some exchanges also may have different requirements depending on the country or the resident status, so it’s always better to check yourself.
That’s exactly the problem. It’s time to stop using centralized exchanges (CEX) that ask for KYC just to cash out. Your ID, selfie and address end up in a database that can be leaked or hacked, and then you become a target. Exchanges can also freeze your account or block withdrawals without warning.
There is a big P2P market where you can trade crypto for cash in person, cash by mail, or bank transfer. Besides not having to send your documents to anyone, it’s often easy to sell with a premium, sometimes up to 10%.
There are a few good platforms for this, but I’m not sure I can name them here. If you want to trade in person or just learn more, check if there is a Bitcoin meetup in your area. People there are usually happy to help, and to trade too.
Your view is skewed. You see only support requests when something goes wrong, for reasons you don’t know. You don’t see the majority of transactions when nothing goes wrong.
Exchanges don’t block anyone just for the heck of it. They are in business of making money, not blocking anyone left and right. There is always a backstory, complainers never tell.
Either way, “inevitable” is a wrong word. Possible — yes. But you know what else is possible? Forgetting your passphrase, or otherwise using access to your self custody wallet. Self-custody does not magically make the funds harder to lose.
I don’t think the jewelry-in-your-own-safe analogy works.
A self-custody wallet is more like a safe where the combination itself is the asset: lose it and the funds are gone forever; leak it and someone can empty it remotely. The risk moved. It did not disappear.
Sure, keep them for the short time. Watch for transaction and withdraw automatically.
