Storj node frisch installiert aber immer offline
Hallo bin neu hier . Ich habe Vodafone 1000gbit/s und versuche seid tagen storj node zum laufen zubringen auf windows 10. ich habe firewall udp/tcp port 28967 freigegeben und in der fritzbox habe ich den dyndns anbieter (,feste-IP.n et ) angegeben. Weiß aber nicht ob das richtig war.
2021-12-30T23:19:04.542+0100 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2021-12-30T23:19:04.542+0100 INFO Operator email {“Address”: “email”}
2021-12-30T23:19:04.542+0100 INFO Operator wallet {“Address”: “token”}
2021-12-30T23:19:05.245+0100 INFO Telemetry enabled {“instance ID”: “18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp”}
2021-12-30T23:19:05.323+0100 INFO db.migration Database Version {“version”: 53}
2021-12-30T23:19:05.589+0100 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2021-12-30T23:19:06.457+0100 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2021-12-30T23:19:06.457+0100 INFO Node 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp started
2021-12-30T23:19:06.457+0100 INFO Public server started on [::]:28967
2021-12-30T23:19:06.457+0100 INFO Private server started on 127.0.0.1:7778
2021-12-30T23:19:06.457+0100 INFO trust Scheduling next refresh {“after”: “5h25m51.660277966s”}
2021-12-30T23:19:06.457+0100 INFO bandwidth Performing bandwidth usage rollups
2021-12-30T23:19:26.681+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “12L9ZFwhzVpuEKMUN UqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “attempts”: 1, “error”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp) at address de3.portmap 64.ne t:28967: rpc: context deadli ne exceeded”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nB zP8WLdNva6969A3mY3vuayBzD6jp) at address de3.portm ap 6 4.ne t :28 967: rpc: c ontext deadline exceeded\n\ts t orj .io/s to rj/storagenode/contact.
(*Service).pingSatelliteOnce: 141\n\t storj. io/st orj/sto rage node/contact.
(*Service).pingSatellite:95\n\tstorj . io/storj/st oragenode/contact.
(*Chore).updateCycles.func1:87\n\tstorj. io/common/sync2.(*C ycle).Run:92\n\tstorj. io/common/sync2.(*Cycle).Start.func1:71\n\tgolang. org/x/sync/errgrou p.
(*Group).Go.func1:57”}
2021-12-30T23:19:26.701+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “attempts”: 1, “error”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp) at address de3
.portmap64.net:28967: rpc: context deadline exceeded”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp) at address de3 .portmap64.net:28967: rpc: context deadline exceeded\n\tstorj .io/storj/storagenode/contact.(*Service) .pingSatelliteOnce:141\n\tstor j. io/storj/storagenode/contact.(*Service).pingSatellite: 95\n\tstorj .io/st orj/storagenode/contact.(*Chore).updateCycles. func1:87\n\tstorj .io/common/sync2.(*Cycle). Run: 92\n\tstorj .io/common/sync2.(*Cycle).Start.func1:71\n\tgolang .org/x/sync/errgroup .(*Group).Go.func1:57”}
2021-12-30T23:19:27.050+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “attempts”: 1, “error”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp) at address de3 .portmap64.net:28967: rpc: context deadline exceeded”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp) at address de3 .portmap64.net:28967: rpc: context deadline exceeded\n\tstorj .io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj .io/storj/storagenode/contact.
(*Service) .pingSatellite:95\n\tstorj .io/storj/storagenode/contact.(*Chore) .updateCycles.func1:87\n\tstorj .io/common/sync2.(*Cycle) .Run:92\n\tstorj .io/common/sync2.(*Cycle).Start.func1:71\n\tgolang .org/x/sync/errgroup.(*Group) . Go .func1:57”}
2021-12-30T23:19:27.112+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “attempts”: 1, “error”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp) at address de3 .portmap64.net:28967: rpc: context deadline exceeded”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp) at address de3 .portmap64.net:28967: rpc: context deadline exceeded\n\tstorj .io/storj/storagenode/contact.(*Service) .pingSatelliteOnce:141\n\tstorj .io/storj/storagenode/contact.(*Service) .pingSatellite:95\n\tstorj .io/storj/storagenode/contact.(*Chore) .updateCycles.func1:87\n\tstorj .io/common/sync2.(*Cycle) .Run:92\n\tstorj .io/common/sync2.(*Cycle).Start.func1:71\n\tgolang .org/x/sync/errgroup.(*Group) .Go.func1:57”}
2021-12-30T23:19:27.212+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “attempts”: 1, “error”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp) at address de3 .portmap64.net:28967: rpc: context deadline exceeded”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp) at address de3 .portmap64.net:28967: rpc: context deadline exceeded\n\tstorj .io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj .io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj .io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj .io/common/sync2.(*Cycle).Run:92\n\tstorj .io/common/sync2.(*Cycle).Start.func1:71\n\tgolang .org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-12-30T23:19:27.648+0100 ERROR contact:service ping satellite failed {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “attempts”: 1, “error”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp) at address de3 .portmap64.net:28967: rpc: context deadline exceeded”, “errorVerbose”: “ping satellite: failed to dial storage node (ID: 18bUaFfEDQokKh5o67o9nBzP8WLdNva6969A3mY3vuayBzD6jp) at address de3 .portmap64.net:28967: rpc: context deadline exceeded\n\tstorj .io/storj/storagenode/contact.(*Service).pingSatelliteOnce:141\n\tstorj .io/storj/storagenode/contact.(*Service).pingSatellite:95\n\tstorj .io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj .io/common/sync2.(*Cycle).Run:92\n\tstorj .io/common/sync2.(*Cycle).Start.func1:71\n\tgolang .org/x/sync/errgroup.(*Group).Go.func1:57”}
2021-12-30T23:19:37.213+0100 ERROR nodestats:cache Get pricing-model/join date failed {“error”: “payouts service: unable to connect to the satellite 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs: rpc: read tcp 192.168.0.41:50488->34.141.33.112:7777: wsarecv: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.”, “errorVerbose”: "payouts service: unable to connect to the satellite 12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs: rpc: read tcp 192.168.0.41:50488->34.141.33.112:7777: wsarecv: Ein Verbindungsversuch ist fehlgeschlagen, da die Gegenstelle nach einer bestimmten Zeitspanne nicht richtig reagiert hat, oder die hergestellte Verbindung war fehlerhaft, da der verbundene Host nicht reagiert hat.\n\tstorj .io/storj/ sto ragenode/payouts.(*End point).dial:231\n\tstorj .io/storj/storagenode/payouts.(*E ndpoint).GetAllPayments:190\n\tst orj .io/st
könnte mir bitte einer weiterhelfen oder zusammen mit mir der storj node aufsetzen vieleicht?
Geht die Verbindung über TV-Kabel? Falls ja hast Du wahrscheinlich ‘Dual Stack Lite’ (DS-Lite) mit einer privaten IPv4-Adresse bekommen (CGNAT, Carrier Grade Network Address Translation).
Private Adressbereiche:
  • Klasse A: 10.0.0.0 bis 10.255.255.255.
  • Klasse B: 172.16.0.0 bis 172.31.255.255.
  • Klasse C: 192.168.0.0 bis 192.168.255.255.
Wie ist deine IPv4-Adresse? In der Fritzbox unter Internet → Online Monitor zu finden.
Ja ich habe DS-Lite von Vodafone 1gbit/s.
Kabel verbunden, ↓ 1150 Mbit/s↑ 56,7 Mbit/s
Internet, IPv4 FRITZ!Box verwendet einen DS-Lite-Tunnel
Internet, IPv6 verbunden seit 30.12.2021, 13:42 Uhr
Genutzte DNS-Server 1.1.1.1
2606:4700:4700::1111
2606:4700:4700::1001 (aktuell genutzt für Standardanfragen)
1.0.1.8|
Da liegt das Problem, die IPv4-Adresse 1.0.1.8 gehört wohl eigentlich jemanden in China:
https://ipinfo.io/1.0.1.8
Eine für Privatkunden übliche dynamische IPv4-Adresse wirst Du nicht bekommen, da die Kabel-Betreiber nicht über genug Adressen für alle Kunden verfügen. Eine statische Adresse bekommt man als Geschäftskunde, aber natürlich kostet so etwas mehr und das Geld für den höheren Preis bringt Dir STORJ nur nach mehreren Jahren. (1000MBit/s = 54.90€)
https://zuhauseplus.vodafone.de/business/kabel/
Wie sieht es mit klassischem DSL mit Vectoring bei Dir aus?
ok ich habe auf business gestellt. jetzt habe ich eine feste it wenn sie mögen können wir es über discord/ts/teamviewer/skype oder teams zusammen machen bin voll überfordert . habe nochmal alles neu installiert nach den guide
C:\Users\xxxx>telnet 192.168.0.41 28967
Verbindungsaufbau zu 192.168.0.41…Es konnte keine Verbindung mit dem Host hergestellt werden, auf Port 28967: Verbindungsfehler
nach diesem guide habe ich alles gemacht
Meine Nodes laufen alle unter Debian Linux & Raspberry OS (basiert auf Debian), also bin ich nicht die geeignete Hilfe für Nodes unter Windows.
Zum Telnet Verbindungsfehler: Firewall-Eintrag nach dem Tutorial ist erstellt?
Man kann sich mit dem Befehl
netstat -a -p TCP
anzeigen lassen auf welchen Ports eines Rechners auf Verbindungen gewartet wird, dabei sollte der Port 28967 des Nodes dabei sein wenn der Node läuft.
TCP 0.0.0.0:28967 Computername:0 ABHÖREN
Noch ein Tip zur IP-Adresse des Rechners mit dem Node, auf jeden Fall eine feste, statische benutzen.
Um die Erreichbarkeit des Ports von außerhalb zu testen gibt es zum Beispiel:
https://www.yougetsignal.com/tools/open-ports/
ein rasberry habe ich auch xd pi4 xd denn wollte ich danach machen . Dachte windows wäre einfacher
hi wie gehts ihnen ich hoffe alles gut
