Hallo, Ich habe mir heute Morgen einen account als Host erstellt, jedoch ist dieser seit heute morgen offline. Ich kann mir nicht erklären woran es liegt, ich habe einige sachen aus dem Forum versucht, aber leider Ergebnislos.
2020-04-27T08:11:20.813+0200 INFO tracing disabled
2020-04-27T08:11:24.151+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2020-04-27T08:11:24.164+0200 INFO tracing disabled
2020-04-27T08:11:24.170+0200 INFO Operator email {“Address”: “XXX”}
2020-04-27T08:11:24.170+0200 INFO Operator wallet {“Address”: “XXX”}
2020-04-27T08:11:28.487+0200 INFO db.migration Database Created {“version”: 36}
2020-04-27T08:11:31.938+0200 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2020-04-27T08:11:32.819+0200 INFO preflight:localtime local system clock is in sync with trusted satellites’ system clock.
2020-04-27T08:11:32.820+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T08:11:32.820+0200 INFO trust Scheduling next refresh {“after”: “8h2m33.859969079s”}
2020-04-27T08:11:32.820+0200 INFO Node 1AR4FD3UvyRdKczWSYqoLi3di5XS8kGFp8WymTdxfr493U5ojF started
2020-04-27T08:11:32.820+0200 INFO Public server started on [::]:28967
2020-04-27T08:11:32.820+0200 INFO Private server started on 127.0.0.1:7778
2020-04-27T09:11:32.822+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T10:11:32.821+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T11:11:32.820+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T12:11:32.821+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T13:11:32.821+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T14:11:32.820+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T15:11:32.820+0200 INFO bandwidth Performing bandwidth usage rollups
PS C:\Users\oswal> ls (sls “identity.cert-path: (.*)” ‘C:\Program Files\Storj\Storage Node\config.yaml’).Matches.Groups[1].Value
Den Port musst du manuell freigeben. Die automatische Portfreischaltung am besten deaktivieren, ist ein Sicherheitsrisiko. Ist so fast die bloedeste Erfindung, die es gibt. Damit kann jeder (verseuchte) Rechner selbstaendig Ports oeffnen.
Anscheinend funktioniert das dennoch nicht, ich habe gerade getestet ob der Port feigegeben wurde auf dieser seite https://www.yougetsignal.com/tools/open-ports/?port=28967 jedoch scheint er immer noch nicht freigegeben. Die IP-Adresse die eingegeben worden ist habe ich so übernommen, hat das damit evt. was zutun ?
Die Portfreigabe sieht ok aus. Ich sehe allerdings nicht im Bild, ob der Port an den richtigen PC weitergeleitet wird. Hast du den Port auch in der Windows-Firewall geoeffnet? Wenn dann noch der Node laeuft, sollte der Port als “open” angezeigt sein.
Wenn du keine feste IP von deinem ISP hast, solltest du auch DynDNS in der Fritzbox einrichten. Dafuer kannst du das Myfritz!-Konto benutzen, ist kostenlos. Andere Anbieter verlangen Geld oder du musst den Account alle paar Wochen bestaetigen.
Das ist deine aktuelle externe IP und diese sollte jetzt erstmal funktionieren. Wenn du keine statische IP hast, ist die aber in spätestens 24h nicht mehr korrekt, deshalb auch noch der Hinweis auf DDNS.
Ich habe eine Statische IP, von daher habe ich diesen Schritt auch übersprungen. Laut dem Dashboard ist der aktiv seitdem ich es installiert habe ( Uptime 13h 49min, wenn es das richtige ist)
Im Taskmanager schein Storagenode.exe zu laufen, dort ist die UAC-Virtualisierung deaktiviert, falls es was damit zutun hat
Wie mache ich das? Hab gerade nochmal versuch eine neue Ausnahme zu erstellen, jedoch hab ich da nichts von Remote gesehen.
Im Log hat sich aufjedenfall was geändert, der sieht jetzt so aus :
PS C:\Users\oswal> cat -tail 20 “$env:ProgramFiles\Storj\Storage Node\storagenode.log”
2020-04-27T16:11:32.821+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T16:14:07.208+0200 INFO trust Scheduling next refresh {“after”: “8h55m50.733040075s”}
2020-04-27T17:11:32.821+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T18:11:32.821+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T19:11:32.820+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T20:11:32.821+0200 INFO bandwidth Performing bandwidth usage rollups
2020-04-27T21:11:32.822+0200 INFO bandwidth Performing bandwidth usage rollups
PS C:\Users\oswal>
Ja, ich denke ich hab das Problem mittlerweile gefunden. Mein Anschluss typ ist der DS-Lite, dadurch habe ich keine eigene Ipv4 adresse und teile sie mir mit vielen Leuten, deswegen sind die portfreigaben auch nutzlos. Deswegen werde ich später bei vodafone anrufen und das ganze auf dual stack umstellen lassen, dann sollte ich eine eigene Ipv4 adresse bekommen und dann müsste das in der Theorie funktionieren wenn es nicht noch ein Problem gibt. Wie sieht das jetzt mit der offline Zeit aus? Kann ich deswegen gebannt werden weil ich nicht verbunden bin?
Ich meine doch dass wir das Thema hier vor 2-3 Tagen schon mal hatten und dort auch DS-Lite schuld war.
Momentan werden Nodes nicht für Downtimes Disqualifiziert.
Und deiner hatte ja bisher eh noch keinen Kontakt zum Server, also alles gut.
Du kannst dir auch jederzeit eine neue Identität erstellen. Einfach eine neue Einladung anfordern und neu generieren.
Das habe ich nicht gesehen. Jetzt aber zurück zu meinem Problem, ich habe jetzt eine eigene Ipv4 adresse, muss ich jetzt alles neu installieren oder kann ich das irgendwo einpflegen?
