Storj node sevice become offline after few minutes
Hi All! After Start of Storj node service it belomes offline in a few minutes. Reboot doesn’t help.
Status of service I can see is “Running”, but by fact is not, by right click system propose to run it.
What could be the problem?
Win10, laptom witn USB 3.5 externall HDD.
Regards,
Alexander
check the logs in program files/storj/storagenode folder, it will show error
Is it this one?
2022-09-25T17:18:53.926+0300 ERROR piecestore:cache error getting current used space: {“error”: “CreateFile F:\Storj2\blobs\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\ao/jmpiiyndo23nadxsjnzunczzxdcjf4dwhr4w2mgatifjmup74a.sj1: The file or directory is corrupted and unreadable.”, “errorVerbose”: “CreateFile F:\Storj2\blobs\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\ao/jmpiiyndo23nadxsjnzunczzxdcjf4dwhr4w2mgatifjmup74a.sj1: The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storage/filestore.walkNamespaceWithPrefix:788\n\tstorj.io/storj/storage/filestore.(*Dir).walkNamespaceInPath:725\n\tstorj.io/storj/storage/filestore.(*Dir).WalkNamespace:685\n\tstorj.io/storj/storage/filestore.(*blobStore).WalkNamespace:284\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePieces:498\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:663\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2022-09-25T17:18:53.928+0300 ERROR services unexpected shutdown of a runner {“name”: “piecestore:cache”, “error”: “CreateFile F:\Storj2\blobs\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\ao/jmpiiyndo23nadxsjnzunczzxdcjf4dwhr4w2mgatifjmup74a.sj1: The file or directory is corrupted and unreadable.”, “errorVerbose”: “CreateFile F:\Storj2\blobs\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\ao/jmpiiyndo23nadxsjnzunczzxdcjf4dwhr4w2mgatifjmup74a.sj1: The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storage/filestore.walkNamespaceWithPrefix:788\n\tstorj.io/storj/storage/filestore.(*Dir).walkNamespaceInPath:725\n\tstorj.io/storj/storage/filestore.(*Dir).WalkNamespace:685\n\tstorj.io/storj/storage/filestore.(*blobStore).WalkNamespace:284\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePieces:498\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:663\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
2022-09-25T17:18:53.942+0300 INFO piecestore upload canceled {“Piece ID”: “RDIQO4RMTE4NVK6GFNETFDFS27EBUGI6JV2K4IHUVBPBK7NOM3BA”, “Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “Action”: “PUT”, “Size”: 311296}
2022-09-25T17:18:53.942+0300 INFO piecestore upload canceled {“Piece ID”: “2FBSD7QT4XW6BTGFH7TOUWDD4CH3ZB263PVTEGKU25ORCBRQ3N5A”, “Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “Action”: “PUT”, “Size”: 532480}
2022-09-25T17:18:55.263+0300 FATAL Unrecoverable error {“error”: “CreateFile F:\Storj2\blobs\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\ao/jmpiiyndo23nadxsjnzunczzxdcjf4dwhr4w2mgatifjmup74a.sj1: The file or directory is corrupted and unreadable.”, “errorVerbose”: “CreateFile F:\Storj2\blobs\ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa\ao/jmpiiyndo23nadxsjnzunczzxdcjf4dwhr4w2mgatifjmup74a.sj1: The file or directory is corrupted and unreadable.\n\tstorj.io/storj/storage/filestore.walkNamespaceWithPrefix:788\n\tstorj.io/storj/storage/filestore.(*Dir).walkNamespaceInPath:725\n\tstorj.io/storj/storage/filestore.(*Dir).WalkNamespace:685\n\tstorj.io/storj/storage/filestore.(*blobStore).WalkNamespace:284\n\tstorj.io/storj/storagenode/pieces.(*Store).WalkSatellitePieces:498\n\tstorj.io/storj/storagenode/pieces.(*Store).SpaceUsedTotalAndBySatellite:663\n\tstorj.io/storj/storagenode/pieces.(*CacheService).Run:57\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2.1:87\n\truntime/pprof.Do:40\n\tstorj.io/storj/private/lifecycle.(*Group).Run.func2:86\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57”}
please check disk for errors, looks like disk is corrupted
I checked disk with standard tool, it fix some error and looks it works. Thanks you!
