New here. Need help in setting up 2nd StorJ node on same Windows host using Storj Node Toolbox.
Any basic, easy to follow, instructions?
Can I use same email address?
Can I use same wallet?
Concerned that any changes made for creation of 2nd node will affect my main running node.
Vadim
2
yes you can use all the same, only ports and identity shold be unic
I’m getting error port 14003 already in use on Node:Dashboard:localhost:14003 when clicking install
Vadim
4
what port you used on first node? or how much nodes do you have there?
Its OK, I’ve changed port number to a known spare port, and now working
