Heya,
Due to power fluctuations (and USB + Raspi4 has issues, I do not know what was the problem but now it seems to be running fine),
my storage node has not been able to run continuously and was offline for 2 weeks or so.
The node is not old (still in 4-6 months) and since the suspension for one of the satellites is around 95%, others are at 100 still.
And the online status is between 83-85% for almost all satellites.
The audit is 100% so assuming no data loss on my node
My questions:
- is it advisable to reset the storage node and then restart again?
- should I continue to run this node for a while? The question is more related to whether the system will recover from this and the reputation be back for the node?
Any guidance much appreciated. Thank you.
