i try install qnap 1.1.4 on QNAP Service unvailable
manual settings not workin from putty, any qnow?
- Enable Container Station and ssh
- Generate your identity on PC/Mac, sign it with an authorization token and transfer the identity folder to your QNAP; or generate and sign it on your QNAP with app (it just can take a week rather a few hours on PC/Mac).
- Check your identity: Confirm the identity (if you already transferred an identity, you need to update path to the identity location in the check command).
- Login via ssh to QNAP
- Figure out what is your paths to the identity and data in the command line. If you used an qnap app, then you can execute this command to get paths:
docker inspect storjlabsSnContainer -f '{{.Mounts}}'
- Remove the QNAP app
- Run the setup step: Storage Node - Setup once, replacing
"<identity-dir>"and"<storage-dir>"to their actual values (the<and>should be removed as well). Never run this command in the future for the same identity. - Run a regular container: Storage Node - Run the node
- Check your logs: How do I check my logs? - Storj Node Operator Docs
See also an alternative way: Qnap Storagenode - #3 by sean
not working,
- identity generateg and copying to /homes/admin/identity
- node Folder: /homes/admin/storjnode
docker still not starting
command from putty not working
i have problem witch path does no exist… what i made wrong?
Did you manage to enable a Container Station? Does your QNAP supports docker at all?
Please provide a command and response for “not working” situation.
By default, if you select a text in the PuTTY window, it will be copied to the clipboard, so, please paste it here between two new lines with three backticks, like this:
copied text here
perhaps it doesn’t exist? I do not know your filesystem structure, but I’m not sure that paths like /homes/ are exists on QNAP. Please check your actual paths.
Usually all user’s data is in /share/ as far as I know,
You may try to use a command
df -h
to identify mounted paths.
or at least
ls -l /share/
Filesystem Size Used Available Use% Mounted on
none 400.0M 280.0M 120.0M 70% /
devtmpfs 3.9G 8.0K 3.9G 0% /dev
tmpfs 64.0M 784.0K 63.2M 1% /tmp
tmpfs 3.9G 136.0K 3.9G 0% /dev/shm
tmpfs 16.0M 0 16.0M 0% /share
/dev/sdi5 7.7M 47.0K 7.3M 1% /mnt/boot_config
tmpfs 16.0M 0 16.0M 0% /mnt/snapshot/export
/dev/md9 493.5M 142.1M 351.3M 29% /mnt/HDA_ROOT
cgroup_root 3.9G 0 3.9G 0% /sys/fs/cgroup
/dev/mapper/cachedev1
50.5T 17.3G 50.5T 0% /share/CACHEDEV1_DATA
/dev/md13 417.0M 388.7M 28.3M 93% /mnt/ext
tmpfs 48.0M 60.0K 47.9M 0% /share/CACHEDEV1_DATA/.samba/lock/msg.lock
tmpfs 16.0M 0 16.0M 0% /mnt/ext/opt/samba/private/msg.sock
50.5T 17.3G 50.5T 0% /lib/modules/4.14.24-qnap/container-station
tmpfs 100.0K 0 100.0K 0% /share/CACHEDEV1_DATA/Container/container-station-data/lib/lxd/shmoun ts
tmpfs 100.0K 0 100.0K 0% /share/CACHEDEV1_DATA/Container/container-station-data/lib/lxd/devlxd
I guess this is your disk for data. So, you need to create a storagenode folder here, place the identity folder here and use the storagenode folder to store storagenode’s data.
