Storj - out of sync
Ia it free? The last time I looked at that, it was behind paid subscription
It used to be called Argo Tunnels (I think), and it was paid. Since then it was renamed to Zero Trust and is now part of free account.
Thank you. It was written as subscription only, but they never wrote that the subscription is 0€/Month.
I will try and get it to work
Do you know how I can set up the site to only allow my warp connection? It says I have to identify myself. I get a 401 if I remove all identification methods. It sees my warp connection but it won’t let me through
I don’t want to request a otp per email every time I want to access my page
Edit:
Got it working. I had to enable tls decryption
do you know how much time it takes to show up, my device has been up for 17 hours, and storage usage on the hard drive is 77 gigs while on the app shows 17 gigs today
also earnings have also reset, any place where I can keep eye on my earnings ?
I’m not sure which number you are referring to now. Satellites tend to send daily storage usage reports at the least so I would expect it to be up to date right now. Can you post a scree shot of your dashboard for the numbers you are referring to?
Im guess this is mainly set to show monthly stats
Your disk usage for yesterday as reported by the satellites shows 45GB. That’s less than I would expect, but not concerning yet. Make sure your node is always online. I can see that eu1 has a low online score for your node. Todays reports are likely still incomplete. I would give it a little more time and that graph should settle closer to the used space number on the right. I don’t see anything that worries me just yet, but it’s a little hard to tell with limited data at the start of the month. Just keep it online and check in a few days.
If you want you can run this: Earnings calculator (Update 2024-04-14: v13.4.0 - Additional info on uncollected garbage and unpaid data - Detailed earnings info and health status of your node, including vetting progress)
It’ll give you some more stats, but it also relies on satellite data. So if that’s still incomplete, you may see similar mismatches.
Here’s an example of what that calculator might show.
Older nodes are having some issues with garbage collection, so that’s why this one shows large amounts of trash and uncollected garbage. I wouldn’t expect to see that on a new node like yours.
i swapped over from 1 tb to 2 tb so my machine was off for some time most likely that’s the reason.
i think it’s been around 1 week since having setup the storj. that’s why low and also it’s on HDD.
connection is 1 gig but I have connected it to cat 5 cable to limit to 100ish mb, but if yesterday is .
Thanks its on anyway will check the status in couple of days
I’ve setup GitHub authentication. It asks me for login once every month at most, and browser auto-fills it. Vast majority of the time it is frictionless.
I got it resolved in another way. I added my phone as a gateway user. And the set a policy that if the user is a warp and gateway user it can access the site.
As far as I read, the user can only get the gateway flag if the person is listed in my company user list. So no login needed there
Oh, if you have a warp connection — that’s definitely the way to go.
