Storj simulator satellite is crashing on startup. Anyone get the simulator to work?
(Below is more details in the error I’m seeing)
Switched to the master branch and using the Dockerfile below seems to get things going
FROM ubuntu:20.04
ENV DEBIAN_FRONTEND noninteractive
RUN apt-get update
RUN apt-get install -y make wget curl vim git gcc redis-server inetutils-ping net-tools npm
RUN wget -c https://dl.google.com/go/go1.14.2.linux-amd64.tar.gz -O - | tar -xz -C /usr/local
ENV PATH=$PATH:/usr/local/go/bin:/root/go/bin/
Issue fixed by @ egonelbre
Our current config handling is somewhat unintuitive. So if you use a release branch (properly tagged) or downloaded then it will run in “production” mode… however, storj-sim should always run in dev mode.
I’ll make a fix to ensure all the binaries are started in “dev” mode.
