Hello,
is there a good instruction to access my SNO Dashboard on my network? I opened the port, but nothing helped. Do you have a hint?
Thanks in advance.
Hello,
Thanks in advance.
Hello,
What about your system windows/docker in linux?
Sorry I missed that. Its a windows 10 .exe installation. (not docker)
did you opened findows firewall? also if you want see dashboard in local network, in config need to write pc network ip not localhost
Try this https://www.windowscentral.com/how-open-port-windows-firewall?amp
Open port 14002 inbound on all networks
Yes, port is open. Which point I need to change in the config file?
console.address: 192.168.88.242:14002, if it is comented, then remoove coment mark
Thanks! That helped!
how many nodes do you have there?
only one and not more
why not? i have 60+TB here runing ok worth it.
Half of my discs are empty.
do you use raid0, or raid 5
