Hi everyone.
Iβm a node operator myself and am currently hosting 5 nodes. I found it cumbersome to always have to sift through the logs of each node in order to look up if any and what filewalkers are currently running. This is why I wrote a little tool summarize all that in a simple way.
Storj Terminal Dashboard
It is pretty simple to use, as you only need to set up the paths to the log and the database of each node in the .json file. You can specify any number of nodes. After that you just have to run the script without any arguments.
Note, that my script only shows the states of each filewalker up to the most recent restart of the node.
I am open to constructive criticism and any suggestions for improvement. Feel free to fork my repo and further improve on it.
Credits to RenΓ© Smeekes and his storj-earnings script, as my terminal dashboard also utilizes his script to pull financial and disk storage data.
Nice
Do we have to shut down the nodes before running the script? Because itβs accessing the databasesβ¦
No, you donβt have to if you are running Linux. Technically my script is not even touching the database. It is just parsing the logs.
The databases are only read by RenΓ©βs script to pull finanical and disk storage data. The limitations of his script still apply, tho. If I recall correctly, you should not use his script without shutting down the nodes and copying the databases, if you are running Windows.
Iβll check that and update the README of my dashboard accordingly.
mike
June 23, 2024, 12:56pm
4
@lukhuber Great work - thanks!
Doesnβt seem to work?
Setup:
Ubuntu 22LTS
Python 3.10.12 (from default repos)
Node in docker, logging to flat files on host filesystem
Daily rotation of logs with logrotate w/gzip.
(node.log - node.log.1.gz - node.log.2.gzβ¦)
I get this output:
storj-tools# ./storj-dashboard.py
[ ~~ ] Reading log of 251 β¦ 484.5/878.0 MB
β¦
ββββββ NODE MAIN STATS ββββββββββββββββββββββ FILEWALKER βββββββββββββββββ
β ββ β
β Current Total: 12.25 $ ββ GARBAGE TRASH USED SPACE β
β Estimated Total: 16.80 $ ββ COLLECTOR CLEANUP FILEWALKER β
β ββ β
β Disk Used: 14.18 TB ββ SL unknown unknown unknown β
β Unpaid Data: 1.17 TB ββ AP1 unknown unknown unknown β
β ββ EU1 unknown unknown unknown β
β Report Deviation: 27.31 % ββ US1 unknown unknown unknown β
β ββ β
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
βββββββββββββββββββββββββββ All Nodes - Summary ββββββββββββββββββββββββββ
β ββ β
β Estimated total: $ 16.80 ββ GARBAGE TRASH USED SPACE β
β ββ COLLECTOR CLEANUP FILEWALKER β
ββββββββββββββββββββββββββββββ β
β SL 0 running 0 running 0 running β
β AP1 0 running 0 running 0 running β
β EU1 0 running 0 running 0 running β
β US1 0 running 0 running 0 running β
β β
However, I know this node was running trash earlier today from itβs logs:
2024-06-22T22:28:48Z INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE"}
2024-06-23T03:45:06Z INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "elapsed": "5h16m17.694585625s"}
2024-06-23T03:45:06Z INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs"}
2024-06-23T03:45:06Z INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "elapsed": "254.999Β΅s"}
2024-06-23T03:45:06Z INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6"}
2024-06-23T03:46:07Z INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "elapsed": "1m1.016199671s"}
2024-06-23T03:46:07Z INFO pieces:trash emptying trash started {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S"}
2024-06-23T03:46:07Z INFO pieces:trash emptying trash finished {"Process": "storagenode", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "elapsed": "16.54863ms"}
A few questions:
Any requirements for logging in storagenode config?
It could make sense to be able to specify more than the main log, so it could ie. look back main log + x gzβed ones.
What is Report Deviation?
The dashboard does not display when trash is emptied as this usually is a rather short process.
It just shows if either the garbage-collector-filewalker, trash-cleanup-filewalker or used-space-filewalker is running.
Maybe your logs got rotated after your all of your filewalkers ran, hence why no states are displayed in the dashboard.
To your questions:
No, you donβt need any special config for your storagenode, in order for this dashboard to run. I recommend tho, to set the logging level to WARN. For your nodes in docker this would mean to include following command in the docker-compose: --log.custom-level=piecestore=WARN
Yes it is planned to be able to also include rotated logs for each respective node. Currently, this is not supported tho. It is only possible to specify one log per node.
Report Deviation is displayed, if RenΓ©βs storj_earnings script is issuing a warning, that the reported disk storage data from the satellites is not accurate. This means that also the data in βNODE MAIN STATSβ in the dashboard is not accurate.
mike
June 23, 2024, 1:37pm
6
Thanks for the answers!
Forced a restart and filewalker run with lazy and scan at startup, now it shows the expected output:
β ββ β
β Current Total: 12.41 $ ββ GARBAGE TRASH USED SPACE β
β Estimated Total: 16.81 $ ββ COLLECTOR CLEANUP FILEWALKER β
β ββ β
β Disk Used: 14.18 TB ββ SL unknown 0d 2h ago running β
β Unpaid Data: 1.19 TB ββ AP1 unknown 0d 2h ago unknown β
β ββ EU1 unknown 0d 2h ago unknown β
β Report Deviation: 27.01 % ββ US1 unknown 0d 2h ago unknown β
β ββ β
β ββ β
β Estimated total: $ 16.81 ββ GARBAGE TRASH USED SPACE β
β SL 0 running 0 running 1 running β
β β
However - timezone is off. Iβm in CET and logs are in Z, so it reports 2 hours off.
Unfortunately, I have no control over the timezones the user has set up. You would have to set the timezone for your node accordingly to show accurate times.
Dhend
June 24, 2024, 8:36am
8
What db files does your script use specifically?
cat /etc/timezone
date +%z
lukhuber:
Issues only occur if you use it over a network protocol like NFS or SMB, due to locking being unreliable on SQLite DBβs in such scenarios. This includes docker nodes on Windows as those implementations use SMB to share the storage. Stopping your node is not necessary if you run everything local.
Will the Filewalker part will work, when limiting the logfile size (I have mine limited to 10MB)? Is it compatible with hosting the nodes in docker?
Alexey
June 25, 2024, 7:46am
12
Perhaps not, unless you also reduced the log level to warn, and this log level should be enough for this dashboard, am I right @lukhuber ?
st99ab
June 25, 2024, 2:45pm
13
Better get rid of the exception?
Always getting this: ValueError: time data β{βlogβ:"2024-06-25Tβ does not match format β%Y-%m-%dT%H:%M:%Sβ
Donβt know how to solve this problem all my logs showing the Tβ¦(using docker and Linux)
I got all running at some time but still donβt know whats going on. Right know itβs not working
This happens, if there is an error with the earnings script. Do you perhaps have an error with the path specification in storj-dashboard.json
But you are right, I should make this error clear in the exception.
Yes, it definitely does. I have reduced my log level to warn also.
Yes it should work. Please note, however, that the information in the dashboard is potentially very inaccurate if you do not allow larger logs.
That is very strange. Your logs are only showing the date of each entry. There should also be a time associated with each entry. What log level are you using?
I am using loglevel: INFO
st99ab
June 25, 2024, 6:40pm
20
I guess it fails here:
self.earnings = subprocess.run(['python3', earningsCalculator, dbPath], capture_output=True, text=True)
I donβt have python3 in my PATH, running the script via "C:\Users\<...>\AppData\Local\Programs\Python\Python312\python.exe" D:\storj-scripts\storj-dashboard.py in a .bat file.
