Storjmetrics.net the Community frontend for stats.storjshare.io
Hi everyone!
Since storjstats.info has lost statistics several times, I’m creating my own version.
I have a different approach:
Ingest the json into a TimeScaleDB database (now TigerData) with a Python script.
Grafana queries the database.
Theoretically, it should handle huge amounts of data efficiently.
I perform daily database dumps, so I shouldn’t lose much.
I’ve also implemented “0 protection.” If storj sends empty metrics again, they should be ignored.
Note: This is just a fun project! I don’t intend to replace anything.
All the code will be released once it’s cleaned up and optimized.
https://storjmetrics.net
Thank you for this! Competition is a good thing. I like it so far. :grin:
New dedicated domain added :slight_smile:
The free-space number doesn’t seem to ever change? storjstats.info has the same issue - is it the wrong field in the json from the satellites?
We both read the official values ​​from https://stats.storjshare.io
If the official value doesn’t change, then the official value is wrong. There’s no way we’ve added thousands of new nodes over the last year… and have not gained a single byte of new free space :wink:
In the overview I take the largest value among the satellites. Including unvetted ones.
The value that is shown is that of US1
I will check if it varies in the other satellites in the next few days, time to collect some data.
It has been reported a while ago. The team is working on a new reporting API, but they also will take a look on this issue.
Thanks - it looks like that free-space number changed… today! After being stuck at the same number since Jan 2025.
Maybe it’s a result of this report :slight_smile:
@anto294 Site offline?
Currently, yes, no new data has been added for a very long time. Furthermore, free space is no longer available.
Too much expense to keep a blank page.
Turns out maintaining a public service requires ongoing work, time, and money. Eight months later, this apparently came as a surprise.
