Strange unknown containers under my Docker
Hi there!
I am new here and I setup my first STORJ node just a couple of days ago. I did that on a Synology NAS and I just noticed that except the container I created there are some more created under Docker containers. You can see them in the below screenshot:
Does anyone knows it this is normal? If not, how the hell these were created? Should I proceed with deleting them or is it part of the storagenode?
Please advise.
With kind regards,
Angelos Pitsos
You should be safe to remove them. Were they created during setup by accident?
you can check the logs of those containers to see the error and perhaps they will give you a hint.
Hi again,
I just deleted them. I had no logs from before. The log was just a few records. I suppose they were deleted with the last restart of the service.
Thank you both!
