Hello, today when I woke up and looked at my node and I get a message that my node has been suspended. What does this mean?
Does it mean that all node time is lost?
What should I do?. Thank you
How can I look at the node logs for errors?
Please, figure out what the error:
Seems you did not read the guide.
Please, search for GET_AUDIT AND failed:
sls GET_AUDIT "C:\Program Files\Storj\Storage Node\storagenode.log" | sls failed
Please, try the modified version:
sls GET_AUDIT "$env:ProgramFiles\Storj\Storage Node\storagenode.log" | sls failed
No, you do not need to. Even in the first time.
To change any parameter you do not need to reinstall the storagenode: https://documentation.storj.io/resources/faq/how-do-i-change-my-parameters-such-as-payout-address-allotted-storage-space-and-bandwidth
When reinstalling, all logs disappeared. And that explains why you don’t see errors anymore.
Once your node is audited, it will exit suspend mode.
So I just have to wait to get out of sleep mode without worrying?
If you do not see errors anymore, and it successfully pass audits, then it should exit suspend mode.
Puedes entrar aquí, y aliviamos un poco el foro. ![]()
