Suspension for just eu1 and europe-north-1. "write: connection timed out"
As title states today I noticed my suspension for just eu1 and europe-north-1 were not looking to good. Following some documentation i was able to pull some logs but need help understanding what is happening or if there is something further I can be looking at?
output of: docker logs storagenode 2>&1 | grep -E “GET_AUDIT|GET_REPAIR” | grep failed
2022-08-08T13:05:00.772Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "FV4XXCXH2RAIEBHDCRK6CFKLLISYAIXMX2DZLQC4S7NXAKETUI4A", "Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "Action": "GET_REPAIR", "error": "untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io on 192.168.1.86:53: read udp 172.17.0.2:42205->192.168.1.86:53: i/o timeout", "errorVerbose": "untrusted: unable to get signee: trust: rpc: tcp connector failed: rpc: dial tcp: lookup saltlake.tardigrade.io on 192.168.1.86:53: read udp 172.17.0.2:42205->192.168.1.86:53: i/o timeout\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).VerifyOrderLimitSignature:140\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).verifyOrderLimit:62\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:498\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:228\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:58\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:122\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:66\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:112\n\tstorj.io/drpc/drpcctx.(*Tracker).track:52"}
2022-08-09T12:05:34.110Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "6FUS5B3NS2OXXX23XGP25M7XOLM67RT55DM7LTNLL62Y6VOJ6A6Q", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->49.12.194.191:35314: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->49.12.194.191:35314: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-09T12:09:37.407Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "4NXWXLNSP5NXKSUATEM5IU3F7GLEQEC433O7GOLBJKLLZ4OKKN5A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->167.235.24.7:36112: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->167.235.24.7:36112: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T05:05:09.398Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "L2UARJIFTI7GFICMXMK6R2ISJTV3SPUINI7YSYLFVGCEMIM3NKQQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->167.235.24.7:43428: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->167.235.24.7:43428: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T05:10:27.351Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "4OJZZDGNOVUZ72FLGBUJGIP3FO6YI7RTXW32VSKC62W6G3VRPWVA", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->49.12.194.191:41030: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->49.12.194.191:41030: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T05:13:10.679Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "BXIPSMORUOWQUZVEXMXPYUX5PWIJ52DFI25KCJLCIDDJSA7VFRVA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->168.119.234.81:52580: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->168.119.234.81:52580: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T05:22:03.418Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "2HWNDHVXYF7FA6VD6KIQITJYY2XDJUBEJP7JT2C3YYAVAPY4DJ7Q", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->94.130.111.189:40008: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->94.130.111.189:40008: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T07:24:20.471Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "IPIE54GIOIUC7VNU33WE6VQWEXC5FHZGV7PMR2ISKMZT5B3WRRQQ", "Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->5.161.74.111:51324: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->5.161.74.111:51324: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T07:30:09.303Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "S3ZLTP7UKYHX6YOKQ5DVNAQRJXNK3V32XMAGJFKIBIAY2JGOVKDA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->116.203.59.22:52016: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->116.203.59.22:52016: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T07:49:46.134Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "57GPMTGSYZ5BRTFXEDJVBJ45DQEZF2ZDRUAROHQ65JZSB4RLFUSQ", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->167.235.19.43:42812: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->167.235.19.43:42812: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T07:59:42.870Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "OIL6P6A4ROXA423OZTRWLWK2U7TSAZINHWQBIVXRJGBAPP5AFZTA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->167.235.24.7:53636: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->167.235.24.7:53636: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T08:01:01.463Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "FTWAQPENTPS4SYAKVVW2ZYMSQ3ENBKHWSURHQHCE2FAXUUS4TNUQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->116.203.195.108:47432: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->116.203.195.108:47432: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T08:03:32.028Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "SR5JXJQE4NCNWKK2LFZHUE5OJTR2KNEDMTEUJB74SZBFB6G3MXNQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->195.201.124.178:35852: use of closed network connection", "errorVerbose": "write tcp 172.17.0.2:28967->195.201.124.178:35852: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T08:25:27.063Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "EBTAEHFVDLQBK26KSRSRCSOU5AY6TP4JUMIXOFRWJQTC4AHXDRCQ", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->94.130.111.189:58856: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->94.130.111.189:58856: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T08:26:48.987Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "PCMTTQJFCVY2IDFU76TQHAWL4K67QVAIDWTUVMDIZBFGX5CNZOPQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->116.203.59.22:50994: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->116.203.59.22:50994: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T10:53:40.246Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "2G77TAXYLYU5UQLBDMP36KJ5RCNYSA3ONP7VXH33GVFEVQTXQQJQ", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->157.90.17.108:50422: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->157.90.17.108:50422: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T12:02:07.511Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "VHUEAKIN36GZDRD7SWHB2QMJEVPOY5ONEZPZWVB4TMN6Z3EN2VCA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->167.235.21.9:50736: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->167.235.21.9:50736: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T12:05:05.946Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "BJEZTTAPG6NKFCHRDQEFNJTEXG534JEB3GXZGXYR2IGEHTMP3RUQ", "Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->167.235.19.43:56608: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->167.235.19.43:56608: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T12:06:40.151Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "JPE4TRLGXK7DVSVPGBGAKINVIDHSRNDCUQUI4NJHLESOWGBOGYYQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->167.235.21.9:44774: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->167.235.21.9:44774: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T12:22:55.511Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "MTWJMIN4XDCGZH32XOJLMPQ53QTK6CLVENCHT7SNDOPAVHRFS5CQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->168.119.234.81:42452: use of closed network connection", "errorVerbose": "write tcp 172.17.0.2:28967->168.119.234.81:42452: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T12:36:30.102Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "TTXGGOIMDRRZZOYE2J5RCMLYKGWQPZ6SZ5ZXK3RIHM6ID4FKBY6A", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->116.203.59.22:43008: write: broken pipe", "errorVerbose": "write tcp 172.17.0.2:28967->116.203.59.22:43008: write: broken pipe\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T12:39:00.890Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "2U7OYGBX2PONN5MFW357MDEEL6CVJNPDQGIPLP3TXZMBWK3NAVSA", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->167.235.21.9:38078: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->167.235.21.9:38078: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T12:56:01.563Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "2XT5NOQXOLBWICWPPLZMM3BHVWJCFDMJDYHFH5EBLQPYTEP5EF3Q", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->167.235.21.9:39036: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->167.235.21.9:39036: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T13:02:01.572Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "BPXA7ERI5WODV465CILCVG26K4VPMA3B4NXTCMYL73NR6ICJ24YA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->157.90.17.108:57450: use of closed network connection", "errorVerbose": "write tcp 172.17.0.2:28967->157.90.17.108:57450: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T13:04:12.571Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "C3IGPCNHTN7B72NFD4YORUGNPO7MIGLR36N4Y74PHFF3UWA3Y23Q", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->157.90.167.123:44664: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->157.90.167.123:44664: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T13:06:05.718Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "QPMQO4ESOKPTGJVWKY5CEYKYER6F3GO7EIOVAFXMMDLW5K5XSZVQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->167.235.21.9:38958: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->167.235.21.9:38958: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T13:06:23.304Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "FQUPK5YRMC24T2A3TUNC4B4Y6UIBYEPCGSG6NCJOPYDSKPZCLJNQ", "Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->195.201.124.178:51762: use of closed network connection", "errorVerbose": "write tcp 172.17.0.2:28967->195.201.124.178:51762: use of closed network connection\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
2022-08-10T13:13:29.622Z        ERROR   piecestore      download failed {"Process": "storagenode", "Piece ID": "R5M3OO4OMPZ2B5KKX5W7WXLODT5MUE7C4PIB47A3PYWWTROZYWCA", "Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "Action": "GET_REPAIR", "error": "write tcp 172.17.0.2:28967->167.235.24.7:42926: write: connection timed out", "errorVerbose": "write tcp 172.17.0.2:28967->167.235.24.7:42926: write: connection timed out\n\tstorj.io/drpc/drpcstream.(*Stream).rawWriteLocked:326\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:404\n\tstorj.io/common/pb.(*drpcPiecestore_DownloadStream).Send:317\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download.func5.1:620\n\tstorj.io/common/rpc/rpctimeout.Run.func1:22"}
  1. Restart your node. It looks to be slow on the network or storage.
  2. Check logs again and post here.
Restarted.
Previously mentioned command does not have an output currently. Is there something specific I should be looking for?
Speed test results:
Latency:     1.25 ms   (0.32 ms jitter)
   Download:   733.98 Mbps (data used: 461.6 MB )
   Upload:   760.74 Mbps (data used: 777.0 MB )
Packet Loss:     0.0%
Smart stats for disk. Disk is only used for storj node and backups which run nightly.
smartctl -a /dev/sdt
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.39-1-pve] (local build)
Copyright (C) 2002-20, Bruce Allen, Christian Franke, www.smartmontools.org
=== START OF INFORMATION SECTION ===
Device Model:     WDC WD181KFGX-68AFPN0
Serial Number:    x
LU WWN Device Id: 5 000cca 2a6c1bded
Firmware Version: 83.00A83
User Capacity:    18,000,207,937,536 bytes [18.0 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-4 published, ANSI INCITS 529-2018
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Wed Aug 10 13:15:02 2022 EDT
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                (  101) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        No Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        General Purpose Logging supported.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (1756) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
                                        SCT Error Recovery Control supported.
                                        SCT Feature Control supported.
                                        SCT Data Table supported.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   001    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0004   136   136   054    Old_age   Offline      -       96
  3 Spin_Up_Time            0x0007   083   083   001    Pre-fail  Always       -       331 (Average 345)
  4 Start_Stop_Count        0x0012   100   100   000    Old_age   Always       -       27
  5 Reallocated_Sector_Ct   0x0033   100   100   001    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000a   100   100   001    Old_age   Always       -       0
  8 Seek_Time_Performance   0x0004   140   140   020    Old_age   Offline      -       15
  9 Power_On_Hours          0x0012   100   100   000    Old_age   Always       -       1766
 10 Spin_Retry_Count        0x0012   100   100   001    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       25
 22 Unknown_Attribute       0x0023   100   100   025    Pre-fail  Always       -       100
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       103
193 Load_Cycle_Count        0x0012   100   100   000    Old_age   Always       -       103
194 Temperature_Celsius     0x0002   055   055   000    Old_age   Always       -       39 (Min/Max 24/43)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0022   100   100   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0008   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x000a   100   100   000    Old_age   Always       -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
No self-tests have been logged.  [To run self-tests, use: smartctl -t]
SMART Selective self-test log data structure revision number 1
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Selective self-test flags (0x0):
  After scanning selected spans, do NOT read-scan remainder of disk.
If Selective self-test is pending on power-up, resume after 0 minute delay.```
Keep monitoring the suspension score. Wait 30 minutes and run the check logs command again.
It is often hard to know what exactly caused the slow response times which dropped the suspension score.
I hadn’t had time to look at the logs, but I saw the exact same thing on the exact same satellites yesterday. I’m not entirely convinced our nodes are to blame. I’ve never had such drops until a while ago, when it turned out to be an issue in the software. It recovers quite quickly though. I didn’t restart and my scores are back at 100%.
The fact that we saw this on the exact same satellites seems curious to me.
Status at the time of this post:
Node Version v1.60.3
No errors in logs with command provided in initial post. Seems to be recovering. Was alarming as I never had that happen in 1+ years.
