Hello,
During my holiday my computer wich has storj running crashed. I managed to fix it but now all the sattelites say suspension score 100% can i keep it running hoping it goes down or should i uninstall and never use storj again?
Hello,
Mine shows 100% as well. I believe 100% is good. Under 60% will get you suspended
That is perfectly fine. Don’t worry.
oh okay since my node was offline for like 10 days
My node was down for a long time as well just recently, check out this thread:
The node is running great right now.
You can check the tooltip (i) on the web dashboard that provides more info .
