Suspension Score drop by 40% in less than one day
Suspension Score yesterday was 100%, now it shows 75% in Web UI and 60.47% in console for US1.
Payout and held amount by satellite:
│ SATELLITE                      │ HELD AMOUNT │        REPUTATION        │                       PAYOUT THIS MONTH                     │
│              Joined     Month  │      Total  │    Disq    Susp    Down  │    Storage      Egress  Repair/Aud        Held      Payout  │
│ ap1.storj.io:7777 (WARN: Downtime high)      │                          │  $  1.49/TBm $  2.00/TB  $  2.00/TB        0%        100%   │
│              2025-06-03    11  │   $   0.35  │   0.00%   0.00%  30.85%  │  $  0.0070   $  0.0001   $  0.0002  -$  0.0000   $  0.0073  │
│ eu1.storj.io:7777 (WARN: Downtime high)      │                          │  $  1.49/TBm $  2.00/TB  $  2.00/TB        0%        100%   │
│              2025-06-03    11  │   $   0.57  │   0.00%   0.00%  28.28%  │  $  0.0241   $  0.0006   $  0.0005  -$  0.0000   $  0.0252  │
│ saltlake.tardigrade.io:7777 (WARN: Downtime high)                       │  $  1.49/TBm $  2.00/TB  $  2.00/TB        0%        100%   │
│              2025-06-03    11  │   $   0.49  │   0.00%   0.00%  29.99%  │  $  0.0048   $  0.0000   $  0.0002  -$  0.0000   $  0.0050  │
│ us1.storj.io:7777 (WARN: Audits failing)     │                          │  $  1.49/TBm $  2.00/TB  $  2.00/TB        0%        100%   │
│              2025-06-03    11  │   $   9.46  │   0.00%  60.47%  29.85%  │  $  0.3073   $  0.0139   $  0.0052  -$  0.0000   $  0.3264  │
│ TOTAL                          │   $  10.87  │                          │  $  0.3433   $  0.0147   $  0.0060  -$  0.0000   $  0.3640  │
│ ESTIMATED END OF MONTH TOTAL   │   $  10.87  │                          │  $  3.0673   $  0.1221   $  0.0500  -$  0.0000   $  3.2394  │
Scores From Last post around 2 days ago.
I recently fixed a server connection issue and will monitor the score to see if it continues to drop or improve.
Recovered in a few hours, the suspension score fluctuates too fast.
│              2025-06-03    11  │   $   0.35  │   0.00%   0.00%  31.81%  │  $  0.0078   $  0.0001   $  0.0002  -$  0.0000   $  0.0081  │
│              2025-06-03    11  │   $   0.57  │   0.00%   0.00%  28.75%  │  $  0.0271   $  0.0010   $  0.0005  -$  0.0000   $  0.0286  │
│              2025-06-03    11  │   $   0.49  │   0.00%   0.00%  30.62%  │  $  0.0057   $  0.0000   $  0.0002  -$  0.0000   $  0.0059  │
│ us1.storj.io:7777 (WARN: Downtime high)      │                          │  $  1.49/TBm $  2.00/TB  $  2.00/TB        0%        100%   │
│              2025-06-03    11  │   $   9.46  │   0.00%   0.25%  29.99%  │  $  0.3474   $  0.0265   $  0.0064  -$  0.0000   $  0.3802  │
│ TOTAL                          │   $  10.87  │                          │  $  0.3880   $  0.0277   $  0.0072  -$  0.0000   $  0.4229  │
│ ESTIMATED END OF MONTH TOTAL   │   $  10.87  │                          │  $  3.0586   $  0.2030   $  0.0531  -$  0.0000   $  3.3147  │
You need to check for audit errors in your logs:
Only had two, and was on 4-1 and 3-21. (The suspension score drop and recovery were on 4-4).
2026-03-21T15:17:15Z	ERROR	piecestore	download failed	{"process": "storagenode", "piece_id": "BWY3WYG7XL6FJXRZ2PMWA65VMT5PZ5UNLZDFOLAILSJUOTGTI6EQ", "satellite_id": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "action": "GET_REPAIR", "offset": 0, "size": 7168, "remote_address": "66.23.193.251:15147", "error": "hashstore: file does not exist", "errorVerbose": "hashstore: file does not exist\n\tstorj.io/storj/storagenode/hashstore.(*DB).Read:422\n\tstorj.io/storj/storagenode/piecestore.(*HashStoreBackend).Reader:334\n\tstorj.io/storj/storagenode/piecestore.(*MigratingBackend).Reader:197\n\tstorj.io/storj/storagenode/piecestore.(*TestingBackend).Reader:105\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:728\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
2026-04-01T19:33:35Z	ERROR	piecestore	download failed	{"process": "storagenode", "piece_id": "NNKFTAXOKC4BCJPYWBF6QUKTPSIRBUC3FS265HLB3TETJ6TAU5YQ", "satellite_id": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "action": "GET_REPAIR", "offset": 0, "size": 14592, "remote_address": "167.17.78.14:28980", "error": "hashstore: file does not exist", "errorVerbose": "hashstore: file does not exist\n\tstorj.io/storj/storagenode/hashstore.(*DB).Read:422\n\tstorj.io/storj/storagenode/piecestore.(*HashStoreBackend).Reader:334\n\tstorj.io/storj/storagenode/piecestore.(*MigratingBackend).Reader:197\n\tstorj.io/storj/storagenode/piecestore.(*TestingBackend).Reader:105\n\tstorj.io/storj/storagenode/piecestore.(*Endpoint).Download:728\n\tstorj.io/common/pb.DRPCPiecestoreDescription.Method.func2:302\n\tstorj.io/drpc/drpcmux.(*Mux).HandleRPC:33\n\tstorj.io/common/rpc/rpctracing.(*Handler).HandleRPC:62\n\tstorj.io/common/experiment.(*Handler).HandleRPC:43\n\tstorj.io/drpc/drpcserver.(*Server).handleRPC:166\n\tstorj.io/drpc/drpcserver.(*Server).ServeOne:108\n\tstorj.io/drpc/drpcserver.(*Server).Serve.func2:156\n\tstorj.io/drpc/drpcctx.(*Tracker).track:35"}
This shouldn’t suspend your node. But it could be suspended when the online score could drop below 60%.
