Hi, been trying to work this out without much luck
port is open, firewall with exceptions
Hello @astrangerbytheocean ,
Please check everything from this checklist (especially check your public IP and WAN IP):
Thanks , I already run through the troubleshooting link .
I have another node on same static ip running flawlessly on a windows machine.
later edit:
my full log is here:
2022-03-27T09:10:49.224Z WARN contact:service failed PingMe request to satellite {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "error": "ping satellite: check-in network: failed to ping node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address: EDITEDIP:28967, err: contact: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: check-in network: failed to ping node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address: EDITEDIP:28967, err: contact: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).requestPingMeOnce:194\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:167\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:841\n\tstorj.io/storj/storagenode.(*Peer).Run:880\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.ExecCustomDebug:70\n\tmain.main:474\n\truntime.main:255"}
2022-03-27T09:10:49.225Z WARN failed QUIC check {"error": "ping satellite: failed to ping storage node using QUIC: ping satellite: check-in network: failed to ping node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address: EDITEDIP:28967, err: contact: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967 using QUIC: rpc: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: failed to ping storage node using QUIC: ping satellite: check-in network: failed to ping node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address: EDITEDIP:28967, err: contact: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967 using QUIC: rpc: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).RequestPingMeQUIC:176\n\tstorj.io/storj/storagenode.(*Peer).addConsoleService:841\n\tstorj.io/storj/storagenode.(*Peer).Run:880\n\tmain.cmdRun:251\n\tstorj.io/private/process.cleanup.func1.4:363\n\tstorj.io/private/process.cleanup.func1:381\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.ExecCustomDebug:70\n\tmain.main:474\n\truntime.main:255"}
2022-03-27T09:10:49.225Z INFO trust Scheduling next refresh {"after": "7h29m48.992895801s"}
2022-03-27T09:10:49.227Z INFO bandwidth Performing bandwidth usage rollups
2022-03-27T09:10:49.485Z ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:49.654Z ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:49.828Z ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:49.874Z ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:50.700Z ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 2, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:51.167Z ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 2, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:51.208Z ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 2, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:52.915Z ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 3, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:53.805Z ERROR contact:service ping satellite failed {"Satellite ID": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "attempts": 3, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:54.324Z ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID; quic connector failed: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID; quic connector failed: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:54.883Z ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 1, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID; quic connector failed: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID; quic connector failed: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:55.441Z ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 2, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:56.188Z ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 2, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID; quic connector failed: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID; quic connector failed: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:56.957Z ERROR contact:service ping satellite failed {"Satellite ID": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "attempts": 2, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:57.135Z ERROR contact:service ping satellite failed {"Satellite ID": "12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB", "attempts": 4, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:57.564Z ERROR contact:service ping satellite failed {"Satellite ID": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "attempts": 3, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:58.429Z ERROR contact:service ping satellite failed {"Satellite ID": "12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo", "attempts": 3, "error": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID; quic connector failed: quic: timeout: no recent network activity", "errorVerbose": "ping satellite: failed to dial storage node (ID: 128Yn5Wc1TJFqkUmHrbcfFeQ9tLBAGFg5bETnUtYPaaRFaH8z5Y) at address EDITEDIP:28967: rpc: tcp connector failed: rpc: tls peer certificate verification: tlsopts: peer ID did not match requested ID; quic connector failed: quic: timeout: no recent network activity\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:139\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
2022-03-27T09:10:58.494Z ERROR contact:service ping satellite failed {"Satellite ID": "1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE", "attempts": 3, "error": "ping satellite: check-in ratelimit: node rate limited by id", "errorVerbose": "ping satellite: check-in ratelimit: node rate limited by id\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatelliteOnce:136\n\tstorj.io/storj/storagenode/contact.(*Service).pingSatellite:98\n\tstorj.io/storj/storagenode/contact.(*Chore).updateCycles.func1:87\n\tstorj.io/common/sync2.(*Cycle).Run:92\n\tstorj.io/common/sync2.(*Cycle).Start.func1:71\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:57"}
Already ran through the troubleshooter without luck
I also have a second node on same static ip running flawlessly on a windows machine
full log here : error log - Pastebin.com
node is up an running(I was missing config.yaml from my storj directory so I copied it from storage folder and edited it) , although I somehow lost storj data? shows me full free space
later edit: I was using type=bind,source="/volume1/docker/Storj/storage",destination=/app/config \ instead of type=bind,source="/volume1/docker/Storj",destination=/app/config \
But yeah, copying config.yaml to my /Storj/ folder fixed my issue
I now have /Storj/storage/storage/blobs double folder, but node seems to be running fine?
It could be if you specified a wrong directory for your data. The config.yaml for the docker node should be almost empty. You must not specify the storage path in the config.yaml.
# path to the certificate chain for this identity
identity.cert-path: "identity/identity.cert"
# path to the private key for this identity
identity.key-path: "identity/identity.key"
# the public address of the Kademlia node, useful for nodes behind NAT
kademlia.external-address: ""
# operator email address
kademlia.operator.email: ""
# operator wallet adress
kademlia.operator.wallet: ""
#operator.wallet-features: ["zksync"]
# the minimum log level to log
log.level: info
# public address to listen on
server.address: ":28967"
# private address to listen on
server.private-address: "127.0.0.1:7778"
# total allocated bandwidth in bytes
storage.allocated-bandwidth: 500.0 GiB
# total allocated disk space in bytes
storage.allocated-disk-space: 1.0 TB
# Maximum number of simultaneous transfers
# storage2.max-concurrent-requests: 20
All parameters you should specify via variables, as described here: Storage Node | Storj Docs
thanks, check my later edit ^
