Hello Sirs,
It have been working perfectly for many days, but after reboot of system, I got this error. Windows 10, Toolbox. Time on the computer is synced. Special tool shows next:
Logs looks like this:
2024-09-27T21:10:04+03:00 FATAL process/exec_conf.go:428 Unrecoverable error {"error": "system clock is out of sync: system clock is out of sync with all trusted satellites", "errorVerbose": "system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:1009\n\tmain.cmdRun:125\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:428
/go/pkg/mod/github.com/spf13/cobra@v1.8.0/command.go:983
/go/pkg/mod/github.com/spf13/cobra@v1.8.0/command.go:1115
/go/pkg/mod/github.com/spf13/cobra@v1.8.0/command.go:1039
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:112
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:77
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:72
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:62
/go/src/storj.io/storj/cmd/storagenode/service_windows.go:107
/go/pkg/mod/golang.org/x/sync@v0.8.0/errgroup/errgroup.go:78
When is the last time you replace CMOS battery? It could be that - storj was start before ntp time sync, hence the error, replace it and you are good for another 5+ years.
Did you update the port in the config.yaml for the contact.external-address:?
However, it could be closed on yougetsignal, if the node is not running.
Do you maybe have another errors before clock out of sync?
I have the same error in 114.1, tried to run 113 version but it doesnt run of another version of database yet. What is desicion?
2024-09-28T13:11:52+05:00 INFO process/exec_conf.go:318 Configuration loaded {"Location": "C:\\nodes\\027\\config.yaml"}
2024-09-28T13:11:52+05:00 INFO process/exec_conf.go:328 Invalid configuration file key {"Key": "storage2.enable-lazy-filewalker"}
2024-09-28T13:11:52+05:00 INFO process/tracing.go:73 Anonymized tracing enabled
2024-09-28T13:11:52+05:00 INFO operator/operator.go:42 Operator email {"Address": "b.ru"}
2024-09-28T13:11:52+05:00 INFO operator/operator.go:56 Operator wallet {"Address": "0C143b"}
2024-09-28T13:11:53+05:00 INFO db.migration migrate/versions.go:221 Database Version {"version": 62}
2024-09-28T13:11:59+05:00 INFO preflight:localtime preflight/localtime.go:54 start checking local system clock with trusted satellites' system clock.
2024-09-28T13:11:59+05:00 ERROR storagenode/peer.go:1010 Failed preflight check. {"error": "system clock is out of sync: system clock is out of sync with all trusted satellites", "errorVerbose": "system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:1009\n\tmain.cmdRun:125\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
/go/src/storj.io/storj/storagenode/peer.go:1010
main.cmdRun
/go/src/storj.io/storj/cmd/storagenode/cmd_run.go:125
/go/src/storj.io/storj/cmd/storagenode/cmd_run.go:33
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:392
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:410
2024-09-28T13:12:08+05:00 ERROR storagenode/cmd_run.go:50 failure during run {"error": "system clock is out of sync: system clock is out of sync with all trusted satellites", "errorVerbose": "system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:1009\n\tmain.cmdRun:125\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
main.cmdRun.func1
/go/src/storj.io/storj/cmd/storagenode/cmd_run.go:50
main.cmdRun
/go/src/storj.io/storj/cmd/storagenode/cmd_run.go:128
2024-09-28T13:12:08+05:00 FATAL process/exec_conf.go:428 Unrecoverable error {"error": "system clock is out of sync: system clock is out of sync with all trusted satellites", "errorVerbose": "system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:1009\n\tmain.cmdRun:125\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
2024-09-28T11:36:34+03:00 INFO process/exec_conf.go:318 Configuration loaded {"Location": "C:\\Program Files\\Storj0\\Storage Node\\config.yaml"}
2024-09-28T11:36:34+03:00 INFO process/tracing.go:73 Anonymized tracing enabled
2024-09-28T11:36:34+03:00 INFO operator/operator.go:42 Operator email {"Address": "7437493@gmail.com"}
2024-09-28T11:36:34+03:00 INFO operator/operator.go:56 Operator wallet {"Address": "0x0fa586ffb9c23f5a9755ad46da1ebb107ba97636"}
2024-09-28T11:36:34+03:00 INFO db.migration migrate/versions.go:221 Database Version {"version": 62}
2024-09-28T11:36:34+03:00 INFO preflight:localtime preflight/localtime.go:54 start checking local system clock with trusted satellites' system clock.
2024-09-28T11:36:34+03:00 ERROR storagenode/peer.go:1010 Failed preflight check. {"error": "system clock is out of sync: system clock is out of sync with all trusted satellites", "errorVerbose": "system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:1009\n\tmain.cmdRun:125\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
main.cmdRun
2024-09-28T11:36:34+03:00 ERROR storagenode/cmd_run.go:50 failure during run {"error": "system clock is out of sync: system clock is out of sync with all trusted satellites", "errorVerbose": "system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:1009\n\tmain.cmdRun:125\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
main.cmdRun.func1
main.cmdRun
2024-09-28T11:36:34+03:00 FATAL process/exec_conf.go:428 Unrecoverable error {"error": "system clock is out of sync: system clock is out of sync with all trusted satellites", "errorVerbose": "system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:1009\n\tmain.cmdRun:125\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
If the node may check-in on the satellites (and they were able to contact it), it should not be kicked off.
But your logs doesn’t show, that it’s even tried.
the clocks is out of sync (and this seems checked)
the node is not available from outside.
Make sure that the contact.external-address: option contains an IP, which is matched the WAN IP and IP on yougetsignal. And that the port-forwarding rule contains the local IP of your Windows PC, and port is not used by other node. Perhaps you need to forward each port separately, not the range.
Then please try to sync in the Network Time utility.
After that try to start the node.
