There is an upcoming change in the URL.
Yes, but both should work, until all nodes would migrate. There could be a bug in the not yet released 1.114.x
Да это работает, интересно можно все узлы перевести на 1,114,3?
Hi.
After updating three of nodes manually (I do this to control the start of the service, automatic update failed several times in the past) from version v1.113.x to versions v1.114.3, the Windows service does not start, the logs show problem with NTP.
- NTP Windows is available, synchronized both from the OS and using utilities.
- Internet channels are available, different from different providers and in different countries, constant remote access to the nodes, replacing the Internet channel with a VPN does not change anything.
- There is a fourth node on version v1.113.4, it is scary to update.
The problem is on all three, at the same time, immediately after the update, the nodes are down, what to do?
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:62
main.(*service).Execute.func1
/go/src/storj.io/storj/cmd/storagenode/service_windows.go:107
golang.org/x/sync/errgroup.(*Group).Go.func1
/go/pkg/mod/golang.org/x/sync@v0.8.0/errgroup/errgroup.go:78
*2024-10-02T21:30:58+03:00 ERROR storagenode/cmd_run.go:50 failure during run {“error”: “system clock is out of sync: system clock is out of sync with all trusted satellites”, “errorVerbose”: "system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(LocalTime).Check:96\n\tstorj.io/storj/storagenode.
(*Peer).Run:1009\n\tmain.cmdRun:125\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78"}
main.cmdRun.func1
/go/src/storj.io/storj/cmd/storagenode/cmd_run.go:50
main.cmdRun
/go/src/storj.io/storj/cmd/storagenode/cmd_run.go:128
After reading the forum I realized that there is an error in all 114 releases, tell me how to roll back to 113 correctly?
Hello @MilinDV,
This is a mistake. You must NOT update to the dev versions on a production node.
No, it’s better to follow https://version.storj.io
на русском
Нет. Рекомендуется использовать версии только из https://version.storj.io
I have a problem, apparently the node has automatically updated to 1.114.50:
time to error!?wtf))
2024-10-09T01:37:04+03:00 ERROR storagenode/peer.go:1010 Failed preflight check. {“error”: “system clock is out of sync: system clock is out of sync with all trusted satellites”, “errorVerbose”: “system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:1009\n\tmain.cmdRun:125\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”}
/go/src/storj.io/storj/storagenode/peer.go:1010
main.cmdRun
/go/src/storj.io/storj/cmd/storagenode/cmd_run.go:125
/go/src/storj.io/storj/cmd/storagenode/cmd_run.go:33
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:392
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:410
/go/pkg/mod/github.com/spf13/cobra@v1.8.0/command.go:983
/go/pkg/mod/github.com/spf13/cobra@v1.8.0/command.go:1115
/go/pkg/mod/github.com/spf13/cobra@v1.8.0/command.go:1039
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:112
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:77
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:72
The Go Programming Language
2024-10-09T01:37:04+03:00 ERROR storagenode/cmd_run.go:50 failure during run {“error”: “system clock is out of sync: system clock is out of sync with all trusted satellites”, “errorVerbose”: “system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:1009\n\tmain.cmdRun:125\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”}
main.cmdRun.func1
main.cmdRun
2024-10-09T01:37:04+03:00 FATAL process/exec_conf.go:428 Unrecoverable error {“error”: “system clock is out of sync: system clock is out of sync with all trusted satellites”, “errorVerbose”: “system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:1009\n\tmain.cmdRun:125\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.cleanup.func1.4:392\n\tstorj.io/common/process.cleanup.func1:410\n\tgithub.com/spf13/cobra.(*Command).execute:983\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1115\n\tgithub.com/spf13/cobra.(*Command).Execute:1039\n\tstorj.io/common/process.ExecWithCustomOptions:112\n\tstorj.io/common/process.ExecWithCustomConfigAndLogger:77\n\tstorj.io/common/process.ExecWithCustomConfig:72\n\tstorj.io/common/process.Exec:62\n\tmain.(*service).Execute.func1:107\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:78”}
/go/pkg/mod/storj.io/common@v0.0.0-20240913104706-8fd6fa0286a3/process/exec_conf.go:428
I had to switch to version 1.113.4, deleted the database and everything worked and I went to sleep.
We should maybe merge this thread with 🔥 V1.114.5 broken on FreeBSD 13.3-RELEASE - #42 by thepaul
Summary: there are many broken things, not just the trust.sources configuration option. More detail in the above link about why and what, but the solution is to get v1.114.6 which is rolling out now.
I use Windows 2012 r2, version 1.114.5 broke on it too, so it will no longer be supported? I also had the client automatically update from 1.113.2 to 1.114.5 and got a time sync error, although over time everything is fine. I had to return the version and delete the databases ((((
We are continuing to support the same versions of Windows 1.113 did. 1.114.6 should have everything fixed.
Please don’t delete your databases and downgrade, you will likely get disqualified if you do that to the wrong databases.
I’m using win 2012 r2 and now it works on 1.114.6. Question about the minimum OS requirements, how long ago the requirements in the section were updated. I must have missed this news.
Thank for answer
here:
because of
However, later our developers implemented a hack described above, so the binaries are still can work on Windows Server 2012, so no announcements yet. But I would highly recommend to upgrade the OS or migrate to the other OS.
