Well, yes there is a documentation on how to run a node. I do run this and it works fine.
Where I’m stuggeling is, to use the above docker image for “gateway”. I would like to run the “gateway” use Tardigrade as S3 storage but I do not want to run it in Windows but in Docker. I do not find anything about this in the documentation.
I found this image as well and played around with it a few days back. First thing to know is don’t use the :latest tag. It won’t work. Use a recently added tag. I used the following command to start it.
docker run -it -p 7777:7777 --name gateway storjlabs/gateway:2c0e7667-v0.29.4-go1.13.5-amd64
The docker image is kind of neat as it automatically runs setup at first start. Just follow instructions to choose a satellite and enter API key and encryption pass phrase and the AWS access key and secret key will be displayed. It would be nice if there were a :beta tag or something similar to always get the latest release image though. But this’ll do for now.
After setup is done you can detach from the container (ctrl+pq). Stopping and starting the gateway is as simple as.
