im sorry, heres the log:
log, it just repeats that part
2023-06-18T12:56:59.790+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
2023-06-18T12:56:59.790+0200 INFO Anonymized tracing enabled
2023-06-18T12:56:59.806+0200 INFO Operator email {“Address”: “{ideleteditforshowingpurpose}”}
2023-06-18T12:56:59.806+0200 INFO Operator wallet {“Address”: “{ideleteditforshowingpurpose}”}
2023-06-18T12:57:00.741+0200 INFO Telemetry enabled {“instance ID”: “{ideleteditforshowingpurpose}”}
2023-06-18T12:57:00.741+0200 INFO Event collection enabled {“instance ID”: “{ideleteditforshowingpurpose}”}
2023-06-18T12:57:01.793+0200 INFO db.migration Database Version {“version”: 54}
2023-06-18T12:57:02.778+0200 INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
2023-06-18T12:57:23.794+0200 ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6”, “error”: “rpc: tcp connector failed: rpc: dial tcp 34.80.215.116:7777: connectex: No connection could be made because the target machine actively refused it.”, “errorVerbose”: “rpc: tcp connector failed: rpc: dial tcp 34.80.215.116:7777: connectex: No connection could be made because the target machine actively refused it.\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2023-06-18T12:57:23.861+0200 ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “12tRQrMTWUWwzwGh18i7Fqs67kmdhH9t6aToeiwbo5mfS2rUmo”, “error”: “rpc: tcp connector failed: rpc: dial tcp 35.229.65.196:7777: connectex: No connection could be made because the target machine actively refused it.”, “errorVerbose”: “rpc: tcp connector failed: rpc: dial tcp 35.229.65.196:7777: connectex: No connection could be made because the target machine actively refused it.\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2023-06-18T12:57:23.861+0200 ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE”, “error”: “rpc: tcp connector failed: rpc: dial tcp 34.94.153.46:7777: connectex: No connection could be made because the target machine actively refused it.”, “errorVerbose”: “rpc: tcp connector failed: rpc: dial tcp 34.94.153.46:7777: connectex: No connection could be made because the target machine actively refused it.\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2023-06-18T12:57:23.861+0200 ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “12rfG3sh9NCWiX3ivPjq2HtdLmbqCrvHVEzJubnzFzosMuawymB”, “error”: “rpc: tcp connector failed: rpc: dial tcp 35.228.31.57:7777: connectex: No connection could be made because the target machine actively refused it.”, “errorVerbose”: “rpc: tcp connector failed: rpc: dial tcp 35.228.31.57:7777: connectex: No connection could be made because the target machine actively refused it.\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2023-06-18T12:57:44.795+0200 ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs”, “error”: “rpc: tcp connector failed: rpc: dial tcp 34.159.134.91:7777: connectex: No connection could be made because the target machine actively refused it.”, “errorVerbose”: “rpc: tcp connector failed: rpc: dial tcp 34.159.134.91:7777: connectex: No connection could be made because the target machine actively refused it.\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2023-06-18T12:57:44.811+0200 ERROR preflight:localtime unable to get satellite system time {“Satellite ID”: “12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S”, “error”: “rpc: tcp connector failed: rpc: dial tcp 34.150.199.48:7777: connectex: No connection could be made because the target machine actively refused it.”, “errorVerbose”: “rpc: tcp connector failed: rpc: dial tcp 34.150.199.48:7777: connectex: No connection could be made because the target machine actively refused it.\n\tstorj.io/common/rpc.HybridConnector.DialContext.func1:190”}
2023-06-18T12:57:44.811+0200 ERROR Failed preflight check. {“error”: “system clock is out of sync: system clock is out of sync with all trusted satellites”, “errorVerbose”: “system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:905\n\tmain.cmdRun:120\n\tmain.newRunCmd.func1:32\n\tstorj.io/private/process.cleanup.func1.4:399\n\tstorj.io/private/process.cleanup.func1:417\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomOptions:113\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:79\n\tstorj.io/private/process.ExecWithCustomConfig:74\n\tstorj.io/private/process.Exec:64\n\tmain.(*service).Execute.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2023-06-18T12:57:46.533+0200 FATAL Unrecoverable error {“error”: “system clock is out of sync: system clock is out of sync with all trusted satellites”, “errorVerbose”: “system clock is out of sync: system clock is out of sync with all trusted satellites\n\tstorj.io/storj/storagenode/preflight.(*LocalTime).Check:96\n\tstorj.io/storj/storagenode.(*Peer).Run:905\n\tmain.cmdRun:120\n\tmain.newRunCmd.func1:32\n\tstorj.io/private/process.cleanup.func1.4:399\n\tstorj.io/private/process.cleanup.func1:417\n\tgithub.com/spf13/cobra.(*Command).execute:852\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:960\n\tgithub.com/spf13/cobra.(*Command).Execute:897\n\tstorj.io/private/process.ExecWithCustomOptions:113\n\tstorj.io/private/process.ExecWithCustomConfigAndLogger:79\n\tstorj.io/private/process.ExecWithCustomConfig:74\n\tstorj.io/private/process.Exec:64\n\tmain.(*service).Execute.func1:77\n\tgolang.org/x/sync/errgroup.(*Group).Go.func1:75”}
2023-06-18T12:58:38.997+0200 INFO Configuration loaded {“Location”: “C:\Program Files\Storj\Storage Node\config.yaml”}
ps. the port is forwarded, and it able to listen (checked with listen.exe small tool)
