maybe it might interest you
Please check, maybe your node has it too:
The 122 version didnāt solved the problem. The ingress is still down. Dashboard shows overused, but the disk has a lot of free space, and I know for sure the allocated space is not filled. When I startes the migration, both nodes on the same machine had like 5TB of data, from 7TB allocated. Now after 16 days, the migrated node shows overused?!?!, but the other not migrated node shows 5TB as expected.
And I canāt enable full disk allocation feature, because itās Synology.
This is weird. I was not able to reproduce it in storj-up.
Would share with the team
why? And you likely can set a quota.
However, itās not a solution of course.
Could you please try to restart this node?
I have to agree with snorkel. The numbers shown in the web interface is very wrong. 12 of my nodes has finished migrating, they are all on āDedicated diskā. 6 of them has been updated to 122.1
The numbers are wrong both in 121.2 and 122.1 (all nodes has been restarted). The nodes are working fine but the web interface is broken.
This is one of the 122.1 nodes:
[EDIT]
du -sh on the hashstore directory show 2.8TB used (Debian 12 with docker)
My single hashstore node looks like @seanr22a 's. The node is running version 122.1.
du -sh on the hashstore directory show 961GB used (Debian 12 with docker). The huge difference between the avg disk space used numbers and the actual used space have been like this for weeks.
Iāve restarted like 4 times. Node upgrade, DSM upgrade, simple restarts. All walkers finish thier jobs. No errors. Itās just a buggy space calculation in the software.
Just the log entries for hashstore compaction, for curious SNOs:
2025-02-16T05:36:44Z INFO hashstore beginning compaction {"Process": "storagenode", "satellite": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "store": "s1", "stats": {"NumLogs":867,"LenLogs":"0.8 TiB","NumLogsTTL":0,"LenLogsTTL":"0 B","SetPercent":1.0001442678378505,"TrashPercent":0.006859394085655081,"Compacting":false,"Compactions":0,"TableFull":0,"Today":20135,"LastCompact":0,"LogsRewritten":0,"DataRewritten":"0 B","Table":{"NumSet":2197504,"LenSet":"0.8 TiB","AvgSet":421631.6421248835,"NumTrash":25600,"LenTrash":"5.9 GiB","AvgTrash":248225.28,"NumSlots":8388608,"TableSize":"512.0 MiB","Load":0.261962890625,"Created":20132},"Compaction":{"Elapsed":0,"Remaining":0,"TotalRecords":0,"ProcessedRecords":0}}}
2025-02-16T05:36:45Z INFO hashstore compact once started {"Process": "storagenode", "satellite": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "store": "s1", "today": 20135}
2025-02-16T05:36:57Z INFO hashstore compaction computed details {"Process": "storagenode", "satellite": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "store": "s1", "nset": 2170579, "nexist": 2170579, "modifications": true, "curr logSlots": 23, "next logSlots": 23, "candidates": [], "rewrite": [], "duration": "11.870277823s"}
2025-02-16T05:37:08Z INFO hashstore hashtbl rewritten {"Process": "storagenode", "satellite": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "store": "s1", "total records": 2170579, "total bytes": "0.8 TiB", "rewritten records": 0, "rewritten bytes": "0 B", "trashed records": 75390, "trashed bytes": "29.6 GiB", "restored records": 27244, "restored bytes": "8.2 GiB", "expired records": 0, "expired bytes": "0 B"}
2025-02-16T05:37:09Z INFO hashstore compact once finished {"Process": "storagenode", "satellite": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "store": "s1", "duration": "24.105551293s", "completed": true}
2025-02-16T05:37:09Z INFO hashstore finished compaction {"Process": "storagenode", "satellite": "12L9ZFwhzVpuEKMUNUqkaTLGzwY9G24tbiigLiXpmZWKwmcNDDs", "store": "s1", "duration": "24.465421226s", "stats": {"NumLogs":867,"LenLogs":"0.8 TiB","NumLogsTTL":0,"LenLogsTTL":"0 B","SetPercent":0.9999980899555468,"TrashPercent":0.03432310241738654,"Compacting":false,"Compactions":0,"TableFull":0,"Today":20135,"LastCompact":20135,"LogsRewritten":0,"DataRewritten":"0 B","Table":{"NumSet":2170579,"LenSet":"0.8 TiB","AvgSet":426799.393334221,"NumTrash":75390,"LenTrash":"29.6 GiB","AvgTrash":421767.40427112347,"NumSlots":8388608,"TableSize":"512.0 MiB","Load":0.2587531805038452,"Created":20135},"Compaction":{"Elapsed":0,"Remaining":0,"TotalRecords":0,"ProcessedRecords":0}}}
Iām not yet running Storj, just doing my research.
With this approach, nodes may do better with XFS than ext4. Ext4 can lock up momentarily when deleting large files as it deallocates space. I run Kafka, Cassandra, and MySQL in a production environment with gigabyte+ files, and to avoid this issue I use XFS.
With regards to fragmentation, ext4 uses several tricks to avoid it, and particularly relevant for large files are the 128 MB block groups. Ext4 will try to put all the file data in the same block group. When a block group is full it will move on to the next. Writing a few large files will largely avoid fragmentation.
XFS uses allocation groups (Chapter 13). More AGs allow more concurrent writes. If files being written to in parallel are in different allocation groups they wonāt fragment with each other. XFS was designed for parallel reads and writes and excels at log storage (like Kafka logs, Cassandra sstables, so on). It is likely it will perform very well with hashstore. XFS performance can suffer when there is little free space remaining and files get stored across multiple allocation groups. Allocation groups can be up to 1 TB in size, which is the default for filesystems over 4 TB in size (between 128 MB and 4 TB, 4 AGs are used). Hashstore may benefit from having more if more than 4 files are being written concurrently.
I donāt know anyone running XFS here, most are running NTFS, ext4 and ZFS. But if anyone is skilled enough, could try it and make a tunning guide, like the āon tunning ext4 fs for storagenodesā thread.
I saw that most people were running ext4 or zfs, which have their strong points, like the fast commit option I was unaware of. The difference here is the deletion of large files causing an extended write lock. Itās not a concern with deleting small files. It may also not be a problem if ext4 is mounted with data=journal but that creates extra write load in general.
Another thought occurred to me: hashstore should play well with SMR drives. Furthermore, it should work with zoned storage drives if the hashstore files are stored in zones instead, which are typically 256 MB or 1 GB. I donāt want to spend the cash badly enough to get one off eBay to experiment.
Less than a TiB in s1.
Do you have any compaction logs for your s0 store?
migration is āfinishedā in something like 13 days, but there look to be some dangling pieces that cannot be migrated
2025-02-17T07:27:32+01:00 INFO piecemigrate:chore couldn't migrate {"Process": "storagenode", "error": "opening the old reader: pieces error: invalid piece file for storage format version 1: too small for header (0 < 512)", "errorVerbose": "opening the old reader: pieces error: invalid piece file for storage format version 1: too small for header (0 < 512)\n\tstorj.io/storj/storagenode/piecemigrate.(*Chore).migrateOne:318\n\tstorj.io/storj/storagenode/piecemigrate.(*Chore).processQueue:260\n\tstorj.io/storj/storagenode/piecemigrate.(*Chore).Run.func2:167\n\tstorj.io/common/errs2.(*Group).Go.func1:23", "sat": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "id": "WEOQ6T5BYKKB4AZDK23NQNTUURDOP7GHY64NLDVO37C2A4PL7RMQ"}
2025-02-17T07:27:33+01:00 INFO piecemigrate:chore couldn't migrate {"Process": "storagenode", "error": "opening the old reader: pieces error: invalid piece file for storage format version 1: too small for header (0 < 512)", "errorVerbose": "opening the old reader: pieces error: invalid piece file for storage format version 1: too small for header (0 < 512)\n\tstorj.io/storj/storagenode/piecemigrate.(*Chore).migrateOne:318\n\tstorj.io/storj/storagenode/piecemigrate.(*Chore).processQueue:260\n\tstorj.io/storj/storagenode/piecemigrate.(*Chore).Run.func2:167\n\tstorj.io/common/errs2.(*Group).Go.func1:23", "sat": "12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S", "id": "7FY52IOAKIO4WGT56OPC33TQ5JFLKJSU3IGZYUQPUM2EOONJKPVQ"}
the blobs directory has 3.5 GB of files remaining, but they just look like empty two-letter folders that for some reason report a size of 2.7 MB per folder
ncdu 1.18 ~ Use the arrow keys to navigate, press ? for help
--- /StoragePool/Storj/storage/blobs/ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa -------------
e 2.7 MiB [ 0.1% ############# ] /yt
e 2.7 MiB [ 0.1% ############# ] /yd
e 2.7 MiB [ 0.1% ############# ] /yc
e 2.7 MiB [ 0.1% ############# ] /xv
e 2.7 MiB [ 0.1% ############# ] /wy
e 2.7 MiB [ 0.1% ############# ] /wj
e 2.7 MiB [ 0.1% ############# ] /wb
e 2.7 MiB [ 0.1% ############# ] /w3
e 2.7 MiB [ 0.1% ############# ] /vh
e 2.7 MiB [ 0.1% ############# ] /vd
e 2.7 MiB [ 0.1% ############# ] /v3
e 2.7 MiB [ 0.1% ############# ] /uy
e 2.7 MiB [ 0.1% ############# ] /ul
e 2.7 MiB [ 0.1% ############# ] /u6
e 2.7 MiB [ 0.1% ############# ] /u3
e 2.7 MiB [ 0.1% ############# ] /tw
e 2.7 MiB [ 0.1% ############# ] /tn
e 2.7 MiB [ 0.1% ############# ] /sz
e 2.7 MiB [ 0.1% ############# ] /sr
e 2.7 MiB [ 0.1% ############# ] /sk
e 2.7 MiB [ 0.1% ############# ] /sf
e 2.7 MiB [ 0.1% ############# ] /s3
e 2.7 MiB [ 0.1% ############# ] /rt
e 2.7 MiB [ 0.1% ############# ] /rk
e 2.7 MiB [ 0.1% ############# ] /ri
e 2.7 MiB [ 0.1% ############# ] /rb
e 2.7 MiB [ 0.1% ############# ] /qy
Total disk usage: 2.7 GiB Apparent size: 3.0 KiB Items: 1026
In case youāre interested, here are logs of my oldest node (started 02-2020) that currently holds roughly 2.5TB and is fully migrated to hashstore:
... docker logs storagenode1 2>&1 | grep "compact"
2025-02-16T15:58:31Z INFO hashstore beginning compaction {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "stats": {"NumLogs":36,"LenLogs":"31.5 GiB","NumLogsTTL":2,"LenLogsTTL":"1.3 MiB","SetPercent":0.9845225368642283,"TrashPercent":0,"Compacting":false,"Compactions":0,"TableFull":0,"Today":20135,"LastCompact":0,"LogsRewritten":0,"DataRewritten":"0 B","Table":{"NumSet":195008,"LenSet":"31.0 GiB","AvgSet":170498.31046931408,"NumTrash":0,"LenTrash":"0 B","AvgTrash":0,"NumSlots":524288,"TableSize":"32.0 MiB","Load":0.3719482421875,"Created":20132},"Compaction":{"Elapsed":0,"Remaining":0,"TotalRecords":0,"ProcessedRecords":0}}}
2025-02-16T15:59:15Z INFO hashstore compaction acquired locks {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "duration": "44.907143996s"}
2025-02-16T15:59:15Z INFO hashstore compact once started {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "today": 20135}
2025-02-16T15:59:17Z INFO hashstore compaction computed details {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "nset": 196709, "nexist": 196714, "modifications": true, "curr logSlots": 19, "next logSlots": 19, "candidates": [58], "rewrite": [58], "duration": "1.46140901s"}
2025-02-16T15:59:18Z INFO hashstore compact once finished {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "duration": "2.973751187s", "completed": true}
2025-02-16T15:59:18Z INFO hashstore finished compaction {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "duration": "47.920332943s", "stats": {"NumLogs":35,"LenLogs":"31.5 GiB","NumLogsTTL":1,"LenLogsTTL":"0.7 MiB","SetPercent":1,"TrashPercent":0.13433983664011503,"Compacting":false,"Compactions":0,"TableFull":0,"Today":20135,"LastCompact":20135,"LogsRewritten":1,"DataRewritten":"0 B","Table":{"NumSet":196709,"LenSet":"31.5 GiB","AvgSet":171689.8792022734,"NumTrash":55899,"LenTrash":"4.2 GiB","AvgTrash":81165.17003882001,"NumSlots":524288,"TableSize":"32.0 MiB","Load":0.37519264221191406,"Created":20135},"Compaction":{"Elapsed":0,"Remaining":0,"TotalRecords":0,"ProcessedRecords":0}}}
Here:
2025-02-16T22:44:28Z INFO hashstore beginning compaction {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "stats": {"NumLogs":84,"LenLogs":"83.6 GiB","NumLogsTTL":0,"LenLogsTTL":"0 B","SetPercent":1.0446324824690063,"TrashPercent":0,"Compacting":false,"Compactions":0,"TableFull":0,"Today":20135,"LastCompact":0,"LogsRewritten":0,"DataRewritten":"0 B","Table":{"NumSet":399552,"LenSet":"87.3 GiB","AvgSet":234551.10171391958,"NumTrash":0,"LenTrash":"0 B","AvgTrash":0,"NumSlots":1048576,"TableSize":"64.0 MiB","Load":0.38104248046875,"Created":20131},"Compaction":{"Elapsed":0,"Remaining":0,"TotalRecords":0,"ProcessedRecords":0}}}
2025-02-16T22:44:28Z INFO hashstore compact once started {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "today": 20135}
2025-02-16T22:44:29Z INFO hashstore compaction computed details {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "nset": 391274, "nexist": 391274, "modifications": true, "curr logSlots": 20, "next logSlots": 20, "candidates": [], "rewrite": [], "duration": "1.400793419s"}
2025-02-16T22:44:30Z INFO hashstore hashtbl rewritten {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "total records": 391274, "total bytes": "83.5 GiB", "rewritten records": 0, "rewritten bytes": "0 B", "trashed records": 22358, "trashed bytes": "6.4 GiB", "restored records": 0, "restored bytes": "0 B", "expired records": 0, "expired bytes": "0 B"}
2025-02-16T22:44:30Z INFO hashstore compact once finished {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "duration": "2.432951267s", "completed": true}
2025-02-16T22:44:30Z INFO hashstore finished compaction {"Process": "storagenode", "satellite": "121RTSDpyNZVcEU84Ticf2L1ntiuUimbWgfATz21tuvgk3vzoA6", "store": "s0", "duration": "2.673125788s", "stats": {"NumLogs":84,"LenLogs":"83.6 GiB","NumLogsTTL":0,"LenLogsTTL":"0 B","SetPercent":1,"TrashPercent":0.0766574561720715,"Compacting":false,"Compactions":0,"TableFull":0,"Today":20135,"LastCompact":20135,"LogsRewritten":0,"DataRewritten":"0 B","Table":{"NumSet":391274,"LenSet":"83.6 GiB","AvgSet":229280.05119685948,"NumTrash":22358,"LenTrash":"6.4 GiB","AvgTrash":307587.52088737814,"NumSlots":1048576,"TableSize":"64.0 MiB","Load":0.37314796447753906,"Created":20135},"Compaction":{"Elapsed":0,"Remaining":0,"TotalRecords":0,"ProcessedRecords":0}}}
So⦠s0, s1, s2 are the satellites?
I donāt think so, the s0, s1⦠directories are inside the satellite folders.
For each satellite there is an s0 and s1 hashtable. One is the active one that gets all the writes and one is the passive one that can get compacted. We donāt want writes and compact at the same time. So thats why there are 2 of them. And every now and than they will switch roles so that compact gets executed on both one by one.
My solution for these pieces:
find blobs/* -type f -empty -delete
find blobs/* -type d -empty -delete
