Try this:
npm version
npm install -g n
n lts
npm version
Try this:
npm version
npm install -g n
n lts
npm version
thanks and I was able to set it up (needed to sudo the n its, but went well, few warnings only)
however after creating identity successfully, the 3 multimode instructions end up as “multimode: command not found”…
multinode ?: commande introuvable
export PATH=$PATH:$HOME/go/bin
littleskunk always on fire, thanks for the support
unfortunately this did not go through
I had issues compiling as my go was too old, updated to latest version, compiled again all with few warnings ![]()
sounds like multimode is not recognised as an app, but identity was, and if I am not mistaken, identity is also go app?
which identity will tell you if it is running the identity binary in your go directory or from some other unexpected location. On my machine I have 3 different identity versions somewhere deep in my system. That can get confusing.
identity used is /usr/local/bin/identity
That is not the one you are currently compiling and it does mean that you will find the multinode binary in the path that I have written above.
thanks for your efforts @littleskunk but I believe I will give up now as not good enough in compiling stuff on Linux… will need to wait for a multimode dashboard for dummies" step by step tutorial. but much appreciated your support!
You are so close. You should have the binary already.
cd $HOME/go/bin
which go tells me /usr/local/go/bin/go
sounds like something is going wrong when compiling but to be noticed, in the listed
cd $HOME/multinode
go install ./cmd/multinode
go install ./cmd/identity
cd web/multinode
npm install
npm run build
I need to sudo the last npm run build and trust the issue comes from here as it seems I don’t have same path as su vs as std user
giving it another try, I get the below error when restarting all form beginning:
nicolas@inoc-node:~/multinode/web/multinode$ npm run build
multinode@0.0.1 build /home/nicolas/multinode/web/multinode
vue-cli-service build
ERROR Error loading /home/nicolas/multinode/web/multinode/vue.config.js:
ERROR SyntaxError: Unexpected reserved word
/home/nicolas/multinode/web/multinode/node_modules/stylelint/node_modules/cosmiconfig/dist/Explorer.js:54
for await (const place of this.config.searchPlaces) {
at createScript (vm.js:80:10)
at Object.runInThisContext (vm.js:139:10)
at Module._compile (module.js:617:28)
at Object.Module._extensions…js (module.js:664:10)
at Module.load (module.js:566:32)
at tryModuleLoad (module.js:506:12)
at Function.Module._load (module.js:498:3)
at Module.require (module.js:597:17)
at require (internal/module.js:11:18)
at Object. (/home/nicolas/multinode/web/multinode/node_modules/stylelint/node_modules/cosmiconfig/dist/index.js:12:17)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! multinode@0.0.1 build:vue-cli-service build
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the multinode@0.0.1 build script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /home/nicolas/.npm/_logs/2021-02-27T08_33_12_830Z-debug.log
so git clone, go install multinode, go install identity npm install look fine (few warnings on npm install for optional dependencies skipped) and upon npm build, sh*tstorm starts with the above errors. running npm build as sudo allows setup to complete as success but multinode is not recognised as a valid command
and, not master of npm nor of go, but cannot really locate which file is considered exec/is go working like implicit go multinode when inputting multinode as an executable?
Hello,
It took me a while to follow instructions, more than 1 hour for zero result.
Finally build it on macosX, go it running, generated API Key for a node.
but unable to +New Node
Set Node ID; public IP in http://…:port ; API key
push create, nothing happens. nothing in logs.
Checked trice my inputs.
I also had to guess I needed to build storagenode go binary to generate api-key.
The storagenode container could be directly invoked in interactive mode.
Voila
That part is wrong. You have to insert ip:port only. Port should be the same port you have forwarded for the communication to the satellite.
Could someone upload compiled versions of multinode and npm folder? I’ve managed to compile multinode myself, but can’t cope with npm.
This is compiled static content
http://transfer.sh/iTSuB/multinode.tar.gz
@littleskunk, I finally got back to this and got it working. Thanks for the instructions and the additional help.
Based on that Earned column looks like I’ll be able to retire a bit earlier than originally planned, which is an added bonus.
Any chance to get a docker image for it?
i like your earnings, lol
how do i get in on that deal lol
the multinode dash looks nice
I can’t seem to compile it
FROM ubuntu:20.10
RUN apt-get update
RUN DEBIAN_FRONTEND=noninteractive apt-get install -y npm
RUN DEBIAN_FRONTEND=noninteractive apt-get install -y golang
RUN apt-get install -y git
RUN git clone https://github.com/storj/storj -b main multinode
RUN cd /multinode/ && \
go install ./cmd/multinode && \
RUN cd /multinode/web/multinode && \
npm install && \
npm run build
output
[successful layers removed]
Step 7/8 : RUN cd /multinode/ && go install ./cmd/multinode && go install ./cmd/identity
---> Running in 3baa881abf2b
go: downloading github.com/zeebo/errs v1.2.2
go: downloading github.com/spf13/cobra v1.0.0
go: downloading storj.io/private v0.0.0-20210225200021-48b617cbe817
go: downloading go.uber.org/zap v1.16.0
go: downloading github.com/spacemonkeygo/monkit/v3 v3.0.10
go: downloading storj.io/common v0.0.0-20210406151410-a1147267017f
go: downloading github.com/jackc/pgtype v1.6.2
go: downloading golang.org/x/sync v0.0.0-20210220032951-036812b2e83c
go: downloading github.com/zeebo/structs v1.0.2
go: downloading github.com/jackc/pgx v3.2.0+incompatible
go: downloading github.com/spf13/cast v1.3.0
go: downloading go.uber.org/multierr v1.6.0
go: downloading github.com/spf13/pflag v1.0.5
go: downloading github.com/jtolds/monkit-hw/v2 v2.0.0-20191108235325-141a0da276b3
go: downloading storj.io/monkit-jaeger v0.0.0-20210225162224-66fb37637bf6
go: downloading gopkg.in/yaml.v2 v2.3.0
go: downloading github.com/blang/semver v3.5.1+incompatible
go: downloading github.com/spacemonkeygo/spacelog v0.0.0-20180420211403-2296661a0572
go: downloading storj.io/drpc v0.0.20
go: downloading github.com/mattn/go-sqlite3 v2.0.3+incompatible
go: downloading github.com/spf13/viper v1.7.1
go: downloading go.uber.org/atomic v1.7.0
go: downloading github.com/zeebo/admission/v3 v3.0.2
go: downloading golang.org/x/xerrors v0.0.0-20200804184101-5ec99f83aff1
go: downloading github.com/jackc/pgconn v1.8.0
go: downloading github.com/jackc/pgx/v4 v4.10.1
go: downloading github.com/gorilla/mux v1.8.0
go: downloading golang.org/x/sys v0.0.0-20210124154548-22da62e12c0c
go: downloading github.com/btcsuite/btcutil v1.0.3-0.20201208143702-a53e38424cce
go: downloading github.com/mitchellh/mapstructure v1.1.2
go: downloading github.com/jackc/pgproto3 v1.1.0
go: downloading github.com/magiconair/properties v1.8.1
go: downloading github.com/gogo/protobuf v1.3.2
go: downloading github.com/pelletier/go-toml v1.2.0
go: downloading github.com/subosito/gotenv v1.2.0
go: downloading github.com/spf13/jwalterweatherman v1.0.0
go: downloading github.com/jackc/chunkreader v1.0.0
go: downloading github.com/jackc/pgproto3/v2 v2.0.6
go: downloading golang.org/x/crypto v0.0.0-20201221181555-eec23a3978ad
go: downloading github.com/cloudfoundry/gosigar v1.1.0
go: downloading github.com/jackc/chunkreader/v2 v2.0.1
go: downloading gopkg.in/ini.v1 v1.51.0
go: downloading github.com/hashicorp/hcl v1.0.0
go: downloading github.com/jtolds/tracetagger/v2 v2.0.0-rc5
go: downloading github.com/spf13/afero v1.1.2
go: downloading github.com/jackc/pgpassfile v1.0.0
go: downloading github.com/jackc/pgservicefile v0.0.0-20200714003250-2b9c44734f2b
go: downloading github.com/apache/thrift v0.12.0
go: downloading github.com/zeebo/float16 v0.1.0
go: downloading github.com/jackc/pgio v1.0.0
go: downloading golang.org/x/text v0.3.3
go: downloading github.com/fsnotify/fsnotify v1.4.9
go: downloading github.com/calebcase/tmpfile v1.0.2
go: downloading github.com/zeebo/incenc v0.0.0-20180505221441-0d92902eec54
# storj.io/monkit-jaeger
/root/go/pkg/mod/storj.io/monkit-jaeger@v0.0.0-20210225162224-66fb37637bf6/udp.go:158:10: ticker.Reset undefined (type *time.Ticker has no field or method Reset)
# github.com/mattn/go-sqlite3
sqlite3-binding.c: In function 'sqlite3SelectNew':
sqlite3-binding.c:128049:10: warning: function may return address of local variable [-Wreturn-local-addr]
128049 | return pNew;
sqlite3-binding.c:128009:10: note: declared here
128009 | Select standin;
The command '/bin/sh -c cd /multinode/ && go install ./cmd/multinode && go install ./cmd/identity' returned a non-zero code: 2
Is it an issue with the code in the development branch or something on my end?
