I just sent you 2 Storj
thank you, but noob-style, I cannot see them in my wallet yet
That was a L1 transaction.
Here is your L2 test payout: https://rinkeby.zkscan.io/explorer/transactions/sync-tx:8f93ed46b9bec849973ae2b366a05cd3c0abeef93e63925b57995869a1d920ad
not sure I will go into this L2 as it is kinda cryptic to me and I was not able to see this L2 movement in my wallet
Make sure to open the wallet for testnet: https://rinkeby.zksync.io/
Update
STORJ fees have been enabled in production. Now we can count on the best case fees.
@littleskunk How long does it take for the L2 config-change to be recorded in storj system?
Just a restart and with the next checkin your storage node will inform all satellites.
its march now… any one here has the numbers when come to L2 to exchange rates? or L2 to L1 rates?
^ Just execute this and it will tell you the current fee
how do i deposit my storj tokens to zksync using storj token as a fee? I curently have my storj tokens in my MEW wallet. It only shows ethereum as the fee when trying to deposit using meta mask extension on chrome browser. And this is the first time I am using zksync. If I had to use use the wallet address while installing the storj program what address should I use?
Every time I want to desposit my storj tokens to zksync, the confi
rm button disappears.Here is a screeshot taken
That is not possible. The fee can be paid in Storj for L2->L2 and L2->L1. The deposit is L1->L2 and requires you to pay the L1 ETH fee.
If you want to enable zkSync for your address in storagenode: Configuring zkSync Payments - Storj
When you save the config and restart the node, it will update satellite with this information and the next payout will be send to the same address but via zkSync.
When you will receive your payout via zkSync, you can connect your wallet to the https://wallet.zksync.io/ and withdraw your tokens to L1 either to the same address on L1 (default) or to any other L1 address (exchange deposit for example) and pay fee in STORJ tokens.
If you give me your address, I can send testSTORJ on Rinkeby (Ethereum testnet) to allow you to play with it to make yourself familiar with the technology.
You will need to switch the network in your wallet to the Rinkeby and connect to https://rinkeby.zksync.io/account to be able to see testSTORJ and withdraw them to some address on Rinkeby.
When you will be confident how it works, you can switch the wallet back to mainnet and connect it to https://wallet.zksync.io/
I am confused weather I should make a new wallet or use the same old wallet address!
After opening the config.yaml, where should i add the line of zksync (i mean after or before which line, or am I free to add those lines wherever I want?)
And the second question is should I continue the MEW wallet or make a new one in metamask?
That’s up to you. If you make a new one you have to update the address in your node configuration.
What wallet do you guys recommend to use it on zksync?
Which wallet supports L2>L2?
Does all of these wallet support L2?
