Hello, I am trialling to see if I can set up a node successfully on a raspberry, and I can’t seem to make go online, does the fact that I have very low upload speed at this moment is stopping it from going online?
No what stops it from going online is port forwarding. Have you check logs to see what kinda issues are occurring?
You can try this checklist.
When your node is new it will not have any data, so your upload speed is of zero importance. Why don’t you verify that you have set it up correctly first? What guide did you follow? What logs did you read?
