The easiest way to check how long (since when) SN works?
My memory is unreliable and I am looking for the answer to the question asked in the subject ^^
If you havent change your .Cert key files check when those files was generated.
Ill bet theres an docker command but dont know what that could be
Check the storage folder’s date of creation which gets created when you first started the node :slight_smile:
Only SN was first migrated to another machine, then twice to a larger disk …
Also, key generation was not when SN was started … but this is closer to what I remember
However, I still know approximately, not exactly
Same story here.
Two nodes, that are most interesting for me were migrated few times.
Any luck finding node age?
Have you tried the earnings calculator ?
Now in the web dashboard the payment tab gives the node age for each satellite
wiek_wg_satelity
I’ve seen that in changelog, but my nodes under linux, so they will be updated after few days only :smiley:
Thank you. Latest version of earnings - helped :slight_smile:
That number is incorrect for v1.5.2.
The fix is included for v1.6.3 though. https://github.com/storj/storj/commit/18914e4d1af9e79d9246c8172273e325bcb05b24
My version of the node (also a docker on Debian) is v1.5.2, and it seems to me that it showed in an earlier version …
OK, found the way to see it.
T.y.
It shows it, but it’s not correctly calculated in that version. It could be 1 or 2 months off.
With v1.6.3 the number will be correct.
