The problem with the watchtower
@littleskunk
I just installed a watchtower:
watch_local
On docker hub I can see:
Is this normal behavior ???
My GUI system that supports i.a. docker claims I have a version from 11 months ago …
omv_created
Here is a workaround :wink:
Summary
Please, select a 64 bit version, not 32 bit and compare again
I would like to suggest you to remove the image
docker stop watchtower
docker rm watchtower
docker rmi storjlabs/watchtower:latest
and download it again
docker pull storjlabs/watchtower
Then run it: https://documentation.storj.io/setup/cli/software-updates#automatic-updates
This version doesn’t support rolling updates, which is required function.
So, please update storjlabs/watchtower to the current version and include to the regular update process, or contribute this function (update on randomizing time frame) to the original watchtower like a standard option.
I personally have a workaround with the same function (start watchtower at a random time on each server)
Deleting the image (from rmi) and downloading it again doesn’t change anything, still Digest: sha256: 31c0c558ec8adad5ce … and the version like 11 months ago …
and
docker logs watchtower
shows nothing, logs nothing …
It will be replaced with the storagenode-updater. For the docker version too.
What is your distro and arch? uname -a
Debian:
Linux omvzde 4.15.18-30-pve #1 SMP PVE 4.15.18-58 (Fri, 12 Jun 2020 13:53:01 +0200) x86_64 GNU/Linux
and Synology:
Linux synol 4.4.59+ #25426 SMP PREEMPT Wed Jul 8 03:21:29 CST 2020 x86_64 GNU/Linux synology_apollolake_918+
download from some internet cache instead of directly from docker.hub?
Hm, seems it’s correct Digest
storjlabs/watchtower@sha256:31c0c558ec8adad5cec6cb86320c58018289ca22dafa019c31cd5d6f65f03655
So, it’s latest. But what the real problem?
The docker version should be on 1.13.3, it will be updated only after Windows versions, which are on 20% accordingly to
storjlabs / watchtower:
does nothing, log is empty … on Debian, on Synology
containrrr / watchtower:
time = "2020-10-10T12: 16: 59Z" level = debug msg = "Checking containers for updated images"
time = "2020-10-10T12: 16: 59Z" level = debug msg = "Retrieving running containers" ```
etc, etc...
It will do nothing, because there is nothing to do.
Please, wait when the new version of storagenode image will be published.
adding --debug to the command from the official documentation finally showed that the watchtower does something :wink:
@Alexey
can add --debug option to the documentation (link) so that SNO can see in the log what the watchtower is doing ???
better are (docker logs watchtower):
time="2020-10-11T08:35:41Z" level=debug msg="Sleeping for a seconds to ensure the docker api client has been properly initialized."
time="2020-10-11T08:35:42Z" level=debug msg="Retrieving running containers"
time="2020-10-11T08:35:42Z" level=debug msg="There are no additional watchtower containers"
time="2020-10-11T08:35:42Z" level=debug msg="Starting Watchtower and scheduling first run: 2020-10-13 01:44:27 +0000 UTC m=+148125.689440268"
than an empty log …
Otherwise…
the documentation includes:
“Watchtower will look for new updates to the Docker container on Docker Hub every 6 hours”
and in fact it is:
“time =” 2020-10-11T08: 35: 42Z “level = debug msg =” Starting Watchtower and scheduling first run: 2020-10-13 01:44:27 "
and in my opinion it is not 6 hours …
time="2020-10-09T09:29:05Z" level=debug msg="Scheduled next run: 2020-10-09 22:01:43 +0000 UTC"
More like ~12.5 hours
Hm, it’s random between 12 and 72 hours
Yesterday (2020-10-13) I did a server update and had to restart it …
Here’s what I can see from the storjlabs/watchtower log:
time="2020-10-13T01:44:44Z" level=debug msg="Scheduled next run: 2020-10-14 18:53:12 +0000 UTC"
time="2020-10-13T06:29:49Z" level=info msg="Waiting for running update to be finished..."
time="2020-10-13T06:30:32Z" level=debug msg="Sleeping for a seconds to ensure the docker api client has been properly initialized."
time="2020-10-13T06:30:33Z" level=debug msg="Retrieving running containers"
time="2020-10-13T06:30:33Z" level=debug msg="There are no additional watchtower containers"
time="2020-10-13T06:30:33Z" level=debug msg="Starting Watchtower and scheduling first run: 2020-10-15 15:16:09 +0000 UTC m=+204336.408521214"
time="2020-10-13T07:05:34Z" level=info msg="Waiting for running update to be finished..."
time="2020-10-13T07:06:25Z" level=debug msg="Sleeping for a seconds to ensure the docker api client has been properly initialized."
time="2020-10-13T07:06:26Z" level=debug msg="Retrieving running containers"
time="2020-10-13T07:06:26Z" level=debug msg="There are no additional watchtower containers"
time="2020-10-13T07:06:26Z" level=debug msg="Starting Watchtower and scheduling first run: 2020-10-15 22:31:00 +0000 UTC m=+228274.729756129"
Every restart, the storjlabs/watchtower update time limit is moved … that’s how I got it.
Is this how it is supposed to work?
Yes, as I said before:
So something that will restart the watchtower more often than every 12 hours can lead to it not updating anything? (these are theoretical considerations)
Seems so. Why do you need to restart it?
