Previously, there were “connection reset by peer” errors only from bad slow nodes, but now the satellite has started to give me such an error! I have more than 8 thousand such entries in the log
{"L":"ERROR","T":"2023-04-22T07:18:54.351Z","N":"gracefulexit:chore.1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE@saltlake.tardigrade.io:7777","M":"failed to send notification about piece transfer.","Process":"storagenode","Satellite ID":"1wFTAgs9DP5RSnCqKV1eLf6N9wtk4EAtmN5DpSxcs8EjT69tGE","error":"write tcp 10.16.0.2:33892->34.94.153.46:7777: write: connection reset by peer","errorVerbose":"write tcp 10.16.0.2:33892->34.94.153.46:7777: write: connection reset by peer\n\tstorj.io/drpc/drpcstream.(*Stream).rawFlushLocked:401\n\tstorj.io/drpc/drpcstream.(*Stream).MsgSend:462\n\tstorj.io/common/pb.(*drpcSatelliteGracefulExit_ProcessClient).Send:83\n\tstorj.io/storj/storagenode/gracefulexit.(*Worker).Run.func3:101\n\tstorj.io/common/sync2.(*Limiter).Go.func1:49"}
