One of my nodes received the update but is having trouble restarting because of a database mismatch.
If I understand correctly, the updater reloads the old version after the restart.
2026-11-17T09:46:23+01:00 INFO Configuration loaded {"process": "storagenode", "location": "/app/config/config.yaml"}
2026-11-17T09:46:23+01:00 INFO Anonymized tracing enabled {"process": "storagenode"}
2026-11-17T09:46:23+01:00 INFO Operator email {"process": "storagenode", "address": "xxx"}
2026-11-17T09:46:23+01:00 INFO Operator wallet {"process": "storagenode", "address": "xxx"}
2026-11-17T09:46:23+01:00 INFO db.migration Database Version {"process": "storagenode", "version": 62}
2026-11-17T09:46:23+01:00 ERROR failure during run {"process": "storagenode", "error": "Error checking version for storagenode database: validate db version mismatch: expected 28, but current version is 63\n\tstorj.io/storj/private/migrate.(*Migration).ValidateVersions:142\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).CheckVersion:706\n\tmain.cmdRun:91\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:290", "errorVerbose": "Error checking version for storagenode database: validate db version mismatch: expected 28, but current version is 63\n\tstorj.io/storj/private/migrate.(*Migration).ValidateVersions:142\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).CheckVersion:706\n\tmain.cmdRun:91\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:290\n\tmain.cmdRun:93\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:290"}
2026-11-17T09:46:23+01:00 FATAL Unrecoverable error {"process": "storagenode", "error": "Error checking version for storagenode database: validate db version mismatch: expected 28, but current version is 63\n\tstorj.io/storj/private/migrate.(*Migration).ValidateVersions:142\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).CheckVersion:706\n\tmain.cmdRun:91\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:290", "errorVerbose": "Error checking version for storagenode database: validate db version mismatch: expected 28, but current version is 63\n\tstorj.io/storj/private/migrate.(*Migration).ValidateVersions:142\n\tstorj.io/storj/storagenode/storagenodedb.(*DB).CheckVersion:706\n\tmain.cmdRun:91\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:290\n\tmain.cmdRun:93\n\tmain.newRunCmd.func1:33\n\tstorj.io/common/process.InitBeforeExecute.func1.2:389\n\tstorj.io/common/process.InitBeforeExecute.func1:407\n\tgithub.com/spf13/cobra.(*Command).execute:985\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:1117\n\tgithub.com/spf13/cobra.(*Command).Execute:1041\n\tstorj.io/common/process.ExecWithCustomOptions:115\n\tmain.main:34\n\truntime.main:290"}
[storj-node07] 2026-11-17T08:38:46.459537677Z 2026-11-17 09:38:46,459 INFO Set uid to user 0 succeeded
[storj-node07] 2026-11-17T08:38:46.461519817Z 2026-11-17 09:38:46,461 INFO RPC interface 'supervisor' initialized
[storj-node07] 2026-11-17T08:38:46.461660511Z 2026-11-17 09:38:46,461 INFO supervisord started with pid 1
[storj-node07] 2026-11-17T08:38:47.463062926Z 2026-11-17 09:38:47,462 INFO spawned: 'processes-exit-eventlistener' with pid 75
[storj-node07] 2026-11-17T08:38:47.464169153Z 2026-11-17 09:38:47,464 INFO spawned: 'storagenode' with pid 76
[storj-node07] 2026-11-17T08:38:47.465278518Z 2026-11-17 09:38:47,465 INFO spawned: 'storagenode-updater' with pid 77
[storj-node07] 2026-11-17T08:38:47.480050654Z 2026-11-17T09:38:47+01:00 INFO Configuration loaded {"process": "storagenode-updater", "location": "/app/config/config.yaml"}
[storj-node07] 2026-11-17T08:38:47.480067457Z 2026-11-17T09:38:47+01:00 INFO Invalid configuration file key {"process": "storagenode-updater", "key": "healthcheck.details"}
[storj-node07] 2026-11-17T08:38:47.480070124Z 2026-11-17T09:38:47+01:00 INFO Invalid configuration file key {"process": "storagenode-updater", "key": "server.private-address"}
[storj-node07] 2026-11-17T08:38:47.480072289Z 2026-11-17T09:38:47+01:00 INFO Invalid configuration file key {"process": "storagenode-updater", "key": "server.address"}
[storj-node07] 2026-11-17T08:38:47.480074316Z 2026-11-17T09:38:47+01:00 INFO Invalid configuration file key {"process": "storagenode-updater", "key": "operator.wallet"}
[storj-node07] 2026-11-17T08:38:47.480076251Z 2026-11-17T09:38:47+01:00 INFO Invalid configuration file key {"process": "storagenode-updater", "key": "storage.allocated-disk-space"}
[storj-node07] 2026-11-17T08:38:47.480078184Z 2026-11-17T09:38:47+01:00 INFO Invalid configuration file key {"process": "storagenode-updater", "key": "operator.email"}
[storj-node07] 2026-11-17T08:38:47.480080140Z 2026-11-17T09:38:47+01:00 INFO Invalid configuration file key {"process": "storagenode-updater", "key": "contact.external-address"}
[storj-node07] 2026-11-17T08:38:47.480082128Z 2026-11-17T09:38:47+01:00 INFO Invalid configuration file key {"process": "storagenode-updater", "key": "storage.allocated-bandwidth"}
[storj-node07] 2026-11-17T08:38:47.480084040Z 2026-11-17T09:38:47+01:00 INFO Invalid configuration file key {"process": "storagenode-updater", "key": "healthcheck.enabled"}
[storj-node07] 2026-11-17T08:38:47.480093978Z 2026-11-17T09:38:47+01:00 INFO Invalid configuration file key {"process": "storagenode-updater", "key": "console.address"}
[storj-node07] 2026-11-17T08:38:47.480111952Z 2026-11-17T09:38:47+01:00 INFO Invalid configuration file key {"process": "storagenode-updater", "key": "operator.wallet-features"}
[storj-node07] 2026-11-17T08:38:47.480588076Z 2026-11-17T09:38:47+01:00 INFO Anonymized tracing enabled {"process": "storagenode-updater"}
[storj-node07] 2026-11-17T08:38:47.481002652Z 2026-11-17T09:38:47+01:00 INFO Running on version {"process": "storagenode-updater", "service": "storagenode-updater", "version": "v1.155.4"}
[storj-node07] 2026-11-17T08:38:47.481040591Z 2026-11-17T09:38:47+01:00 INFO Downloading versions. {"process": "storagenode-updater", "server_address": "https://version.storj.io"}
[storj-node07] 2026-11-17T08:38:47.518596535Z 2026-11-17 09:38:47,518 WARN exited: storagenode (exit status 1; not expected)
[storj-node07] 2026-11-17T08:38:48.024294194Z 2026-11-17T09:38:48+01:00 INFO Current binary version {"process": "storagenode-updater", "service": "storagenode", "version": "v1.155.9"}
[storj-node07] 2026-11-17T08:38:48.024311594Z 2026-11-17T09:38:48+01:00 INFO New version is being rolled out but hasn't made it to this node yet {"process": "storagenode-updater", "service": "storagenode"}
[storj-node07] 2026-11-17T08:38:48.034127622Z 2026-11-17T09:38:48+01:00 INFO Current binary version {"process": "storagenode-updater", "service": "storagenode-updater", "version": "v1.155.4"}
[storj-node07] 2026-11-17T08:38:48.034144081Z 2026-11-17T09:38:48+01:00 INFO New version is being rolled out but hasn't made it to this node yet {"process": "storagenode-updater", "service": "storagenode-updater"}
[storj-node07] 2026-11-17T08:38:49.035074321Z 2026-11-17 09:38:49,035 INFO success: processes-exit-eventlistener entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
[storj-node07] 2026-11-17T08:38:49.036080823Z 2026-11-17 09:38:49,035 INFO spawned: 'storagenode' with pid 124
[storj-node07] 2026-11-17T08:38:49.036220291Z 2026-11-17 09:38:49,036 INFO success: storagenode-updater entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
[storj-node07] 2026-11-17T08:38:49.090426825Z 2026-11-17 09:38:49,090 WARN exited: storagenode (exit status 1; not expected)
[storj-node07] 2026-11-17T08:38:51.093334396Z 2026-11-17 09:38:51,093 INFO spawned: 'storagenode' with pid 139
[storj-node07] 2026-11-17T08:38:51.136881846Z 2026-11-17 09:38:51,136 WARN exited: storagenode (exit status 1; not expected)
[storj-node07] 2026-11-17T08:38:54.141164847Z 2026-11-17 09:38:54,141 INFO spawned: 'storagenode' with pid 154
[storj-node07] 2026-11-17T08:38:54.191933408Z 2026-11-17 09:38:54,191 WARN exited: storagenode (exit status 1; not expected)
[storj-node07] 2026-11-17T08:38:55.193243175Z 2026-11-17 09:38:55,193 INFO gave up: storagenode entered FATAL state, too many start retries too quickly
[storj-node07] 2026-11-17T08:38:57.195042966Z 2026-11-17 09:38:57,194 WARN received SIGQUIT indicating exit request
[storj-node07] 2026-11-17T08:38:57.195144937Z 2026-11-17 09:38:57,195 INFO waiting for processes-exit-eventlistener, storagenode-updater to die
[storj-node07] 2026-11-17T08:38:57.195239621Z 2026-11-17T09:38:57+01:00 INFO Got a signal from the OS: "terminated" {"process": "storagenode-updater"}
[storj-node07] 2026-11-17T08:38:57.197320403Z 2026-11-17 09:38:57,197 INFO stopped: storagenode-updater (exit status 0)
[storj-node07] 2026-11-17T08:38:58.198311447Z 2026-11-17 09:38:58,198 WARN stopped: processes-exit-eventlistener (terminated by SIGTERM)
It appears that the updater is distributing a version lower than the minimum required.
Updater 1.155.4
Storage Node 1.155.9
