They give me a storj node
Good afternoon.
They give me a storj node with 1.8gb of data.
They tell me it is on linux.
Could you make a copy of the data with rsync or robocopy?
I would put it on my pc that has windows.
On my computer I have 2 storj nodes. The second node install it with toolbox. I would like to mount the third node with toolbox.
Hi @Vicente, the documentation for migrating a node is here:
As the third node already exists and you’re migrating it then once the data, config and identity have all moved you should be able to add it to the toolbox.
Edit - you’ll also need this info for moving from Linux to Windows:
https://documentation.storj.io/resources/faq/migrate-my-node/migrating-from-docker-cli-to-a-gui-install-on-windows
thanks.
I have gone to “Windows Subsystem for Linux Installation Guide for Windows 10”
He has reached “Step 4-Download the Linux kernel update package”
I can’t install it.
If I go to the next step I can’t finish.1
It doesn’t matter. They are going to format the disk where the storj data is.
So “they” are not giving you anything in the end, is that it?
