To low speed on upload
Win 10, 100Mb LAN. open port. Status node - Online. The disk space used is growing. But after 40h used space only 6.02G … its normal?
Yes it is very normal.
Hello @Sleepy_PIP and welcome to the forum !
You might want to check out the following thread to estimate what to expect for the coming months:
It’s an estimator and as such it won’t 100% accurate, but it’s usually pretty good as its maintener keeps it up to date so it reflects how the Storj network behaves.
Give it a try :slight_smile:
