Good morning everybody,
this is my very first post as I am fairly new to Storj. My node is running now since November and everything is fine so far. Running the Docker image 1.18.1 on Linux.
But since two days I am wondering a bit. When I look into the dashboard the amount in the field “Total Held Amount” does not increase anymore. It is stuck at $0,99. Seems like it is “not possible” to jump over to 1,00.
I have ingress and egress volume, all satelites are at 100%. So everything from this side should be ok.
Many thanks for your help.
