Traffic and nodes
Hi all, can someone tell me if you get less traffic with a new node,as I don’t seem to get much with my new node.
Thanks
Any new node must be vetted, it can receive only 5% of potential traffic until got vetted. To be vetted on one satellite it should pass 100 audits for it. For the one node it should take at least a month.
Also, space and bandwidth are used by real people, not machines. There is no predictable traffic or usage.
Great thanks for that sorry I keep asking questions
If you have questions try using the search to see if that question has been asked.
Ok I should of thought of that,I will next time thanks
No problem its just easier cause most likely people have asked the same question many times, chances are there’s already an answer to it.
