Transferring Node
I’ve transferred 8TB to a new server and have shutdown the original node. Currently I’m waiting for the rsync --delete to remove deleted files. Can I start the newly transferred node as this process is running?
I wouldn’t do that. There are at least all the *.db-shm and *.db-wal files, which will get deleted while the databases are open. There will also be temp, order and trash files which will be created in the new location when you start the node.
I figured it wouldn’t be a good idea :slight_smile: I’ll keep waiting for this process to finish. Thanks~
