Trash does not go away in 7 days
Seems the current workaround is:
I have the same problem on two of my nodes
Is this solution something permanent or something temporary?
Can I leave this alone or do I have to change lazzy walker to true after a while?
Would this be the correct configuration?
storage2.piece-scan-on-startup: true
something temporary
Yes and you may change it back, when it would be fixed. You may track the release changes either on our GitHub or here, Search results for 'release preparation order:latest' - Storj Community Forum (official)
yes
I have found a bug in my storj node.
The trash reported from the dashboard is 194.72GB in size, but on the filesystem the trash folder is: Size 43.39 GB (46,589,713,717 Bytes). 252050 Files, 4163 Folder containing.
The blob folder is 0.8TB in the dashboard, but in the filesystem it is Size: 749.56 GB (804,830,621,172 Bytes). 3866749 Files, 4100 Folder
I think, this is ok, this referes to the rounding of the dashboard.
So, what can I do to correct the trash size in the dashboard?
The node is running at version 1.102.3 since 360h. no other bugs detected. (Default Docker container)
Instead of reastarting the docker with the lazzy filewake. Is there a possibility of running a shell command in the docker directly without restarting and loosing downtime?
Probably this is what you need to do:
Yep, the workaround posted by @jammerdan should help.
But there is no shell command to do that inside the docker container?
Which would be the docker ENV variables for that configuration, or will that problem be solved in 1.1.04.3, and if yes, when will the update be out?
You can. Just put these options after the image name, i.e.:
docker run .... \
storjlabs/storagenode:latest \
--pieces.enable-lazy-filewalker=false
I hope so. I cannot track, because there is no issue on the GitHub.
