Its been a month and trash is still not getting removed, how can i initiate a scan so that it removes this and i regain the space.
Also in the config i found
storage.allocated-disk-space: 2.00 TB
should this not be higher 10 TB
since my disk is 10 TB total
Check logs. I’m sure it’s being removed, slowly. Unlinking files take a lot of time.
Command line parameters have a precedence above parameters in the config file, so for the docker setup you provide all parameters in the docker run command.
Please check, does your trash subfolder actually has date-named folders older than 7 days. If you have them, you may delete them manually, but then please enable scan on startup, if you disabled it and restart the node. Make sure that the used-space-filewalker finished without issues for all trusted satellites.
