I was on the last step of setting up the node and when i typed this command in the terminal window: docker run -d --restart unless-stopped --stop-timeout 300 -p 28967:28967 -p 127.0.0.1:14002:14002 -e WALLET=“0x*************************************************” -e EMAIL="**************************" -e ADDRESS=“mcborovstoragenode.ddns.net:28967” -e STORAGE=“536GB” --mount type=bind,source="<C:\Users\Disk-server\AppData\Roaming\Storj\Identity\storagenode\ca.key>",destination=/app/identity --mount type=bind,source="<A:\Storage>",destination=/app/config --name storagenode storjlabs/storagenode:beta
it would always say "docker:error response from daemon: invalid mount config for type “bind”: invalid mount path: ‘/app/indentity’.
See ‘docker run --help’.
You might wanna try without the “<>” symbols.
It look like a typo indentity. ?
It looks like you’re trying to use docker on Windows. I’d recommend using the Windows installer instead of the CLI method, docker on windows does not seem to be very stable.
That worked! Thanks dude
