I’m seeing the following errors after trying to restart my node:
2020-08-01T16:00:54.596868980Z 2020-08-01T16:00:54.590Z WARN trust Failed to fetch URLs from source; used cache {“source”: “https://tardigrade.io/trusted-satellites”, “error”: “HTTP source: Get https://tardigrade.io/trusted-satellites: dial tcp: lookup tardigrade.io on 192.168.0.1:53: read udp 172.17.0.2:40106->192.168.0.1:53: i/o timeout”, “errorVerbose”: “HTTP source: Get https://tardigrade.io/trusted-satellites: dial tcp: lookup tardigrade.io on 192.168.0.1:53: read udp 172.17.0.2:40106->192.168.0.1:53: i/o timeout\n\tstorj.io/storj/storagenode/trust.(*HTTPSource).FetchEntries:63\n\tstorj.io/storj/storagenode/trust.(*List).fetchEntries:90\n\tstorj.io/storj/storagenode/trust.(*List).FetchURLs:49\n\tstorj.io/storj/storagenode/trust.(*Pool).fetchURLs:240\n\tstorj.io/storj/storagenode/trust.(*Pool).Refresh:177\n\tstorj.io/storj/storagenode.(*Peer).Run:688\n\tmain.cmdRun:200\n\tstorj.io/private/process.cleanup.func1.4:359\n\tstorj.io/private/process.cleanup.func1:377\n\tgithub.com/spf13/cobra.(*Command).execute:840\n\tgithub.com/spf13/cobra.(*Command).ExecuteC:945\n\tgithub.com/spf13/cobra.(*Command).Execute:885\n\tstorj.io/private/process.ExecWithCustomConfig:88\n\tstorj.io/private/process.ExecCustomDebug:70\n\tmain.main:320\n\truntime.main:203”}
2020-08-01T16:00:54.618152413Z 2020-08-01T16:00:54.617Z INFO preflight:localtime start checking local system clock with trusted satellites’ system clock.
Have you tried changing your DNS on the node to 8.8.8.8 yet? Who makes your router and are you hardwired to it or trying to use wifi (highly recommend hardwiring if you’re not already doing that)?
Still haven’t been able to figure out what is going on. I’ve updated my hosts /etc/resolv.conf to add the nameserver 8.8.8.8 entry and restared docker (I’ve also removed the storagenode image and restarted that as well). But no luck so far. The following does not work either:
