Trying to create a bucket: Failed to Fetch
Trying to create my first bucket. I select all the options and when I press Create I get an error message: Failed to Fetch. What’s up?
More details needed. How are you trying to create a new bucket? Where do you see/what tool reports the error message?
On their website. I just created a trial account and went to try and create a new bucket and I got the failed to fetch error message.
Which browser did you use ?
Hello @dpearceFL,
This is usually happen if something is blocking connections to our services.
So, please disable VPN, adBlockers, PiHole or similar, perhaps on your router or ISP or use a mobile browser or the mobile internet.
If you are from Chine or Russia, then you likely need to use a VPN to bypass the Great Firewall.
I do use PiHole. Can you give me the URL to whitelist?
When creating a bucket on us1.storj.io in the browser tools I’m seeing requests to auth.storjsatelliteshare.io and gateway.storjshare.io
