Get yourself a coffee, today we dive.
New Jargon
(First, have a look at Glossary of Storj Network Terms - Storj Docs).
metabase: Not all segment (see in concepts link above) stored on the network, some are so small it best store directly on sat. Sat have 2 databases, one is the normal database called satellitedb, another one called metabase, metabase store segment less or equal 4kiB (configurable) directly inside database. Segment store inside metabase are not using erasure coding, not even it checksum are known to sat (it checksum verify can only be done after decrypt).
Storj/storj Binaries
certificates: in early day, it was used as Certificate Signing Server, nowaday it dead code.
connect-test: test connection (both TCP and QUIC) to a service that use an identity of a peer class.
convert-node-id: a utility tool, it most useful feature probably is to see difficulty level, for example:
./convert-node-id 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S
base58 id: 12EayRS2V1kEsWESU9QMRseFhdxYxKicsiFmxrsLZHeLUtdps3S
hex id: a28b4f04e10bae85d67f4c6cb82bf8d4c0f0f47a8ea72627524deb6ec0000000
blob id: ukfu6bhbboxilvt7jrwlqk7y2tapb5d2r2tsmj2sjxvw5qaaaaaa
version: 0
difficulty: 30
crashcollect: a standalone service for crash collection, similar to datadog/sentry/new relic (?).
diskstat: a utility to monitor disk IO of a process (process as in operating system context).
filewalker-benchmark: a utility to benmark filewalker – probably become legacy after hashstore.
identity: a utility to generate identity of services.
jobq: a queue for repair jobs to be created when segments of data become unhealthy.
jobqtool: a tool to interact with jobq, it can import, len, peek, stat, trim, truncate queue in jobq.
is-valid-sj1-blob: check if blob is valid storj v1 – probably become dead code after hashstore.
metabase-listing-performance: performance benchmarking for listing objects in Storj’s metabase database (guess this one is the tool for benchmarking databases if it fit with the usage pattern of StorJ).
metabase-minimize-listing-csv: not sure what it is yet.
metabase-verify: not sure what it does yet.
metric-receiver: similar to crashcollect, a server to receive metric, combined these two together?
migrate-encryption-master-key:
In satellite-managed project, StorJ use a master key (currently google KMS service) to encrypt a random generated key (called passphrase) before store it in satellitedb. In the event they want to change master key, they will use this tool to decrypt/re-encrypt your passphrase (in self-managed project, you will be the one holding this passphrase).
om-license: Tool for granting Object Mount license entitlements.
piecestore-benchmark: probably become legacy after hashstore.
placement-test: test node placement, for variety purpose, for example: geofencing..
satellite: the satellite.
segment-verify: a diagnostic tool for to verifies whether uploaded file segments are actually present and accessible on the storage nodes where they’re supposed to be stored.
storj-admin: A web UI server for satellite operators to manage and administer a Storj satellite.
storj-sim: probably deprecated after storj/up?
versioncontrol: version control server, similar to https://version.storj.io/
Storj/edge Binaries
authservice: stores and manages Storj access grants, for other services like gateway-mt and linksharing call to.
authservice-admin: A CLI admin tool for operators to manage data inside authservice.
gateway-mt: multi-tenant S3-compatible gateway.
linksharing: The HTTP file-sharing and website-hosting service.
Note that: this is not an exhaustive list, I choose only which relevant to operate a satellite, and with time it will change. See you in part 6.
