Hello,
since today I have a second internet connection and hope that Storj does not need too many surge nodes. (SNO Capacity Planning)
I currently have a Ubiquiti Dream Machine Pro and just realized that it not only has a failover option, but also a built in load balancer.
Would it be sufficient to set up two dynamic DNS records, split my storage nodes in half and start each half with a different dynamic DNS record? Or set them all to the same dyndns entry and leave the load balancing to the router? I’m not sure if this could cause problems? When an external connection to the node is made, it seems to come back through the same internet connection and IP address. I’m not sure how effective load balancing would be with this configuration.
Alternatively, I could use a second router (I got one from my internet provider anyway) and place half of the nodes on this second router on their own network.
Thank you very much for your help!
